HELP¡!¡! Installed winch, nearly burned my truck to the ground
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gunrunner269, May 7, 2019.
  1. May 8, 2019 at 2:32 PM
    Gunrunner269
    Gunrunner269 [OP] Well-Known Member
    The bungle of small wires on the solenoid are all the way it came. I simply added 3 leads to the remote power & in/out grounds to run an in cab switch. I understand it looks like a rats nest but it's really not.
    I just rechecked all the wiring & everything is correct & there's no contact anywhere or anything of that nature. It has to be a bad solenoid. It was either faulty or maybe was dropped & damaged at some point during my recent move.
    Either way, I'm gonna just swap it out with a new solenoid.
    cruiserguy and mynewtoy[QUOTED] like this.
  2. May 8, 2019 at 2:32 PM
    Gunrunner269
    I referenced it with a diagram, everything is wired correctly.
  3. May 8, 2019 at 2:34 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Are you missing a ground wire from your solenoid to your winch?
    I have the Smittybilt XO winch and it’s looks very similar.
    Also the POSITIVE and NEGATIVE wires that go to the battery should be coming from your solenoid, not from the winch.
  4. May 8, 2019 at 3:58 PM
    Gunrunner269
    No, that's not how it's wired.
    There are 4 cables coming off the solenoid, 3 go to the winch & 1 goes to battery positive. A separate cable goes from battery negative to the winch.
    There's also a small lead wire grounded to the solenoid body that goes to the same ground post on the winch as the negative battery cable.
    That's how the manual says to wire it up.
    cruiserguy and mynewtoy like this.
  5. May 8, 2019 at 4:12 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    That is the same as my Warn.
    Let us know if/when the solenoid fixes it. Not really sure what else it could be, the wiring is pretty simple.
  6. May 8, 2019 at 4:32 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Sounds like you got it under control with the new solenoid coming.
  7. May 8, 2019 at 4:39 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Bad solenoids happen more often than your think. If it happens again with a new solenoid, truly try another. You might have to go through 2‐3 new solenoids before things operate correctly.
    Source: I have 3 engineering degrees.
  8. May 8, 2019 at 4:50 PM
    cruiserguy
    Elijah
    SEKS
    I've run into this a few times. Not specifically with winch solenoids but with new in box parts being bad straight out of the box. Happens.
  9. May 8, 2019 at 5:44 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Ok I looked at my diagram again. On mine there’s 4 wires to the winch, one being ground wire. The negative battery wire also connects to the ground wire port on the winch.
  10. May 8, 2019 at 5:52 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Is Page 5 of the instruction manual available?
    mini-rant. I hate throwing parts at problems without diagnosing them. /mini-rant
    Wyoming09 likes this.
  11. May 8, 2019 at 5:58 PM
    cruiserguy
    Elijah
    SEKS
    It would be easy to put the meter on the two hot terminals of the solenoid to see if they show continuity without being powered with the 12VDC. If meter doesn't show OL(open line) or similar then solenoid is stuck closed, broken closed, whatever you wanna call it. It has to stay open until 12VDC are applied
  12. May 8, 2019 at 5:58 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
  13. May 8, 2019 at 6:05 PM
    0xDEADBEEF
    cruiserguy likes this.
  14. May 8, 2019 at 6:09 PM
    cruiserguy
    Elijah
    SEKS
    Yeah all we need is a simple schematic, there are only a handful of circuits and components. Would be pretty easy to without the schematic as well due to simplicity. But it's up to OP if he wants to
  15. May 8, 2019 at 6:14 PM
    #35
    Gunrunner269
    As in bad out of the box or randomly going bad? Because I planned to just run a 500a battery isolator on they battery positive lead to control power via an in cab rocker switch. But now I'm wondering if I should also add an inline fuse or circuit breaker.
  16. May 8, 2019 at 6:15 PM
    #36
    Gunrunner269
    I haven't been able to find any actual schematics other than basic connect A to B type stuff.
    cruiserguy[QUOTED] likes this.
  17. May 8, 2019 at 6:20 PM
    #37
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This is why I like to test new things to ensure they work properly before I start modifying them. It's just too much of a coincidence that the only time I hear something like this happening, OP has modified his wiring. Of course that may not be the issue, but it seems like it.
    Good luck with your resolution OP.
  18. May 8, 2019 at 6:35 PM
    #38
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    I'm hedging bets on that solenoid being faulty.
  19. May 8, 2019 at 6:39 PM
    #39
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Return it to factory configuration and test it.
    If all else fails you can contact smitty and maybe they can send you a replacement solenoid.
    EatSleepTacos likes this.
  20. May 8, 2019 at 6:41 PM
    #40
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Nevermind
