HELP. 1997 2.4 Knock Sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Redfishtony, Feb 5, 2022.
  1. Feb 5, 2022 at 5:37 PM
    Redfishtony
    Redfishtony [OP] Member
    Tony
    1997 Tacoma Extended Cab 2.4 2wd
    Stock
    Ok everyone. This is my first attempt at asking for help. I have a 1997 with the 2.4 motor which has been giving me a PO325 code for several weeks. I have changed the knock sensor 3 times, finally using an expensive one from Toyota. Still throws a code and retards the timing to the point of no power. I used my meter to check for continuity on the wire to the sensor and everything appears to be good. I’m at a COMPLETE loss and don’t know what to check next. Everything I’ve read says the PO325 code should be a bad sensor. Anybody else had this issue. Any ideas or advice will be appreciated. TW
  2. Feb 5, 2022 at 5:48 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Do you get a code if you run higher octane fuel? Try some 91/92 and see if that helps. If it does go from there.
    Does the '97 have a distributor? Could be advanced too far.
    I am not very familiar with the 2.4 of that era so I am of limited help but at this point I would suspect that you do have pre-ignition/knocking and the source of that needs to be addressed.
  3. Feb 5, 2022 at 6:09 PM
    Redfishtony
    Tony
    Stock
    Yes it does have a distributor. I will check the timing tomorrow and see where it’s set. Thanks
    MadNachos likes this.
  4. Feb 11, 2023 at 7:17 AM
    Levisbustedtacoma
    Levisbustedtacoma Well-Known Member
    Levi
    01 4x4 extracab
    Bilstien 5100s eibach coils Dakar leafs Chinese balljoints
    Got a 97 3rz 4runner here and it's the coil pack one no distributor. I need the oem part number for that sensor if anyone has it
  5. Feb 12, 2023 at 6:32 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    You do understand he replaced it several times and still wound up with a goose egg......
  6. Feb 12, 2023 at 6:34 PM
    O'Silver_Taco
    MD
  7. Feb 12, 2023 at 6:40 PM
    Clearwater Bill
    Billy
    Largo Florida
