Help 1999 Tacoma SR5 TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by chadwick31, Aug 18, 2015.
  1. Aug 18, 2015 at 8:17 PM
    chadwick31
    chadwick31 [OP] Member
    Tucson AZ
    99 Tacoma SR5 TRD
    I need help my 1999 Tacoma V6 SR5 driver side door actuator has frozen and I am unable to open the door. Does any one have any videos or ideas how to get it to unfreeze. I have taken off the door panel and have not been able to get it to open. I have checked it with an Ohms meter and their is no power. I have tried to force it open and it did not work. I have been working on it for almost a week now and have not had any success. Any help I would deeply appreciate it.
  2. Aug 19, 2015 at 2:02 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It should unlock with the key and open
    You are in the vehicle can you not just pull the lock up ??.
    if the battery is dead you still need to get in the vehicle
    Did you make some one mad and they super glued your door closed ??
    If you need to just remove the linkage and unlock the door .
    then get a new one
    You should really post where you live someone close could help
  3. Aug 19, 2015 at 6:56 AM
    chadwick31
    Tucson AZ
    99 Tacoma SR5 TRD
    No its not supper glued. From what I have read around the web its the actuator. Im really now on about three weeks of trying to get the door to open. I'm almost tempted to just cut the door off but would like to avoid it. I love my tacoma its the first truck I have bought myself and just want to fix it.
  4. Aug 19, 2015 at 2:19 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Don't you dare!
    Like he said, where are you?
  5. Aug 19, 2015 at 3:24 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Just what is happening ??
    How did this all start??
    I know some of these trucks had a factory anti theft system that when tripped or malfunctions can be a royal pain
    No matter what you do the door will not unlock ??
    It will not even open from the inside??
    You can`t move the lock button by hand ??
    My electric door lock on the left side has never worked yet the door locks and unlocks with the key just fine.
    You have something else going on.
    If you can`t get the door open how can you be sure it has not been glued ??
    Not the lock cylinder but the door it`s self.
  6. Aug 19, 2015 at 7:19 PM
    chadwick31
    Tucson AZ
    99 Tacoma SR5 TRD
    I know it's the actuator. I'm in Tucson Arizona nether inside latch or outside will work. The passenger side door works fine. I try too open it at least an hour or two a day on the weekends until I get mad and need a beer.
  7. Aug 20, 2015 at 12:44 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    You know the problem just buy a new one and your good to go!!
  8. Aug 20, 2015 at 11:43 AM
    chadwick31
    Tucson AZ
    99 Tacoma SR5 TRD
    Well I know what is wrong but I do not know how to get the door open. Once the door is open I'm good to go.
  9. Aug 20, 2015 at 2:47 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Pull the door panel off the door .
    Disconnect what linkage you need to!!!!
    move the rod that controls the lock
    unlock and open the door!!!
    I could be in that truck in about 30 seconds through that door
    More of a pain crawling across the seat removing the door panel
  10. Aug 20, 2015 at 4:18 PM
    chadwick31
    Tucson AZ
    99 Tacoma SR5 TRD
    That's the problem I'm having. I have been trying that and it will not work. I was hoping to see if any one else who had this problem and how they got around it.
  11. Aug 20, 2015 at 6:14 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Have you tried removing the DS seat first? If that is possible, it would make it easier to get the panel off.
  12. Aug 20, 2015 at 6:21 PM
    Madjik_Man
    Colorado Front Range
    My passenger side door lock actuator has been dead for 12 years. The door still operates as a manual door just fine.
  13. Aug 21, 2015 at 1:23 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I tried telling the OP that from the start!!
    Something else is wrong
    I suggested from first hand experience very ugly divorce The door latch was super glued to the striker that was interesting .
    All I can say is get some help
  14. Aug 21, 2015 at 6:57 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Take it to the dealer if you can not go it yourself!
    Tearing off the door is NOT the solution!
  15. Aug 27, 2015 at 9:19 AM
    chadwick31
    Tucson AZ
    99 Tacoma SR5 TRD
    Thank you for all your guys help but now it is an electrical problem lol. I have to give it up talking to salvage yards right now looking at only getting at most 500 for it. But again thank you for all your input.
  16. Aug 27, 2015 at 9:21 AM
    Madjik_Man
    You're scrapping the truck because of this? :confused:
  17. Aug 27, 2015 at 9:23 AM
    chadwick31
    Tucson AZ
    99 Tacoma SR5 TRD
    Im not a mechanic and it would cost thousand of dollars and i can not really afford it. Trust me this is not an easy decision.
  18. Aug 27, 2015 at 9:25 AM
    chadwick31
    Tucson AZ
    99 Tacoma SR5 TRD
    Now when I connect the battery the alarm starts going off and it won't turn over.
  19. Aug 27, 2015 at 9:30 AM
    Kneeboarder1025
    Kneeboarder1025 member-in-training
    Walt
    Broken Arrow, OK
    '03 Forester
    Could you post pics inside your door panel?
  20. Aug 27, 2015 at 9:53 AM
    Madjik_Man
    If you were closer I'd buy the truck from you for $500.
