HELP!! 2003 2.4 - Where the heck is my EGR valve???
Discussion in '1st Gen. Tacomas (1995-2004)' started by DanTacoma03, Jun 3, 2025.
  1. Jun 3, 2025 at 5:44 PM
    DanTacoma03
    DanTacoma03 [OP] New Member
    Was throwing a code that my EGR valve modulator was wonky.. so I pick one up, lift the hood to replace it, and umm… is it gone??? Hiding.. so much for easy. lol
    Was idling rough, power surges.. blinking CEL on highway..
    So, the coils and plugs are new, the head was just resurfaced, gasket replaced… new bolts, new hoses, radiator, O2 sensor, camshaft sensor, water pump, temp sensor, t-stat.. all recently replaced..
    sorry I’m lost.
    here are some pics..
    I’m new to this world, so my apologies in advance.
  2. Jun 4, 2025 at 12:22 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Starting in 02 or 03.....2.4's got rid of egr...
    I believe they fixed the overheating problem from the cat back feeding, by going to a 2 cat system...
    that breaks the wave guide properties so the heads dont overheat on extended hwy use...
    You can see the vac ports that would of fed the egr modulator.....capped off at the factory
    You traded an egr valve that has to be de carboned every 150K.....
    for hopefully 2 cats that last a lifetime.....
    .....at least until it starts burning oil...
    As far as rough idle.....I'd check vac hoses first
    might be worth wild to replace em...
    next would be to clean/inspect the IAC valve, that controls idle
  3. Jun 4, 2025 at 5:00 AM
    DanTacoma03
    I cannot thank you enough. I thought I was losing my mind every picture that engine that I brought up, showed it right there at the top of the engine in the back.
    You mentioned the IAC valve. I looked at my receipt from the work that I had done recently that I mentioned above, and they actually mentioned that that it was not operating consistently and would probably need to be replaced. Of course, after dropping 3000 you would’ve thought they’d replace that anyway. But that’s OK upon looking at the symptoms of a bad IAC looks like you are spot on the symptoms are exactly what I’m seeing.
    Thanks again. This board is awesome and the help is appreciated!
  4. Jun 4, 2025 at 5:05 AM
    DanTacoma03
    question. Is the IAC valve something I can replace pretty easily? If I can get to it, I’m always willing to try.
    well, I just looked at a quick YouTube video and it might be a little beyond my abilities. It just seems like there’s too many things I could potentially screw up lol sadly I am aware of my limitations but then again that might not be such a bad thing!
  5. Jun 4, 2025 at 6:35 PM
    O'Silver_Taco
    MD
    IAC is mounted on/under the throttle body
    so have to remove the throttle body......and take iac off
    and gently clean trying to keep cleaner out of electrical parts
    these usually get gunked up from the egr crap building up
    .....maybe yours is spared of that
    I'm not even sure if yours has iac.....03/04 throttle bodies are very deferent from the previous 8 yrs....its electronic with motor actuated butterfly
    another simple thing is the pvc valve....if that was stuck it would cause idle woes
    and its weird hose wears/deteriorates faster than the rest.....causing vac leaks
    vac leaks are no1 cause of idle problems
    I tell people these are too old for non DIY's....
    ....however with it being '03....you're right on the fence
    starting at about 150K they need a steady investment
    .....lower ball joints on top of that list...
    and competent mechanics are getting hard to find...
