Help! 2004 Tacoma Head replacement (dropped washer)
Discussion in '1st Gen. Tacomas (1995-2004)' started by d3dw8t, Jun 21, 2018.
  1. Jun 21, 2018 at 4:45 AM
    d3dw8t
    d3dw8t [OP] Member
    Andrew
    2004 Gold Tacoma TRD
    Hey Guys was hoping you could help me, while removing the right side head the washer on the head bolt slipped off and fell into the engine. Iam unsure where the port it fell into goes and was wondering if anyone has a diagram of the oil paths. the washer fell down the large path (the only one it would fit down....) on the bottom left side of the head. (top left of picture) Any help would be appreciated!43112.jpg
  2. Jun 21, 2018 at 5:37 AM
    BarnBoy
    BarnBoy Well-Known Member
    96 Tacoma 2wd
    Long magnetic finger to try reach it? If thats an oil galley you are in a pickle. I dont know if it goes back down to the pan or what. If it does maybe you could try knocking it down into the oil pan. It wouldnt hurt anything down there on the bottom of the pan.
    d3dw8t[OP] likes this.
  3. Jun 21, 2018 at 6:08 AM
    tony2018
    tony2018 Well-Known Member
    Snake a cam in the hole and look for it.
    Snake something super sticky to grab it
    Snake some beer down your throat.
    outlawtacoma and d3dw8t[OP] like this.
  4. Jun 21, 2018 at 6:27 AM
    1997tacomav6
    1997tacomav6 V6 5sp,RegCab,TRD Supercharger,Haltech,meth, 750k
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 750,001 plus miles, Original Owner
    V6 5sp,RegCab,TRD Supercharger, 1.9” pulley, methanol injected Haltech ECU, AC TRD supercharger,(MUST DO) TRD supercharger ported, every 125,000- 150,000 needs rebuild Projector headlights HID 5 speed manual Amsoil for all drive train Smaller 2” pulley, (MUST DO) 2004 DESNO fuel injectors, zero ping ping, 2004 side door mirrors Dick Cepek Rims, Michelin tires LTX, ( that last 100,000 miles) Now running Dynopro ATM mud and snow tires KN cold air intake Cat back exhaust with ss exhaust tip, Raised exhaust tail pipe to 2" below body line Optima*dry cell battery,red top Alpine sirius radio, 200 watt amp, focal is165 split door pod speakers Focal door speakers Subwoffer behind seat Viper alarm, Electric Locks Dark tinted windows, bucket seats corbeau lg1 Tacoma Rubber floor mats TRD fender extenders, Bilstien shocks, King shocks nerf bars, add a leaf for rear springs trailer iv hitch, electric brake control, Drilled slotted brakes, High carbon steel (MUST DO) EBS green stuff 7000 series pads(MUST DO) TRD engine oil cap TRD stick shift, Marlin crawl shift kit. Rear sliding window 2002 4Runner functional hood scoop cut into Tacoma hood, 4Runner dual overhead map light Gentex Auto dim + Compass + Temp, garage,rearview mirror Snow Methonal kit stage 2 Custom 3 core aluminum radiator Linex bed liner Haltech stand alone ECU, Intake supercharger gauge. Stainless steel brake lines, Custom leather wrapped steering wheel,
    Get a borescope to look
  5. Jun 21, 2018 at 7:01 AM
    d3dw8t
    d3dw8t [OP] Member
    Andrew
    tony2018 that sounds like what ima need to do lol. BarnBoy thank you for the advice i will try getting something down there to see if i can see it. Hopefully i can get it to drop down into the oil pan
  6. Jun 21, 2018 at 7:05 AM
    1997tacomav6
    Denver
    You can get a borescope tips too and go fishing
    d3dw8t[QUOTED][OP] and tony2018 like this.
  7. Jun 21, 2018 at 7:31 AM
    tony2018
    Forgot about the attachments, awesome.
    1997tacomav6 likes this.
  8. Jun 21, 2018 at 10:05 AM
    d3dw8t
    d3dw8t [OP] Member
    Andrew
    Thanks for all the suggestions guys, just went and bought a scope. Going to try it after i get out of work, will let you know how it turns out
    1997tacomav6 and Area51Runner like this.
  9. Jun 21, 2018 at 11:58 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Shop Vac hooked to small diameter vacuum hose?
  10. Jun 21, 2018 at 12:04 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Just don't do like that other guy who dropped a washer down his engine and start it up... ouy...
    1997tacomav6, BarnBoy and d3dw8t[OP] like this.
  11. Jun 21, 2018 at 12:22 PM
    BarnBoy
    96 Tacoma 2wd
    Yeah that makes a mess. Knew someone who did that with a nut in the cylinder. Beat the crap out of the head and piston. I wouldnt start it with the washer in the engine unless I knew it was for sure in the oil pan.
  12. Jun 21, 2018 at 4:30 PM
    d3dw8t
    d3dw8t [OP] Member
    Andrew
    Well can't get the bore scope down the hole far enough nor can I see it in the oil pan, any suggestions?
  13. Jun 21, 2018 at 4:36 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Take an old antenna (or heck even the one from your tacoma) and magnetize it. It should be thin enough to fit down those valleys.
  14. Jun 21, 2018 at 4:52 PM
    tony2018
    Time to get mission impossible with it and mycgyver something together bro.
  15. Jun 21, 2018 at 5:05 PM
    jbrandt
    Justin
    damn. you sure you know which hole it went down? other than that maybe the shop vac, but seal up all the holes except the one you think it went down. magnetized hanger idea is not bad either.
    Damn man, this is one of those seemingly little insignificant things that ends up being HUGE.
  16. Jun 21, 2018 at 5:26 PM
    d3dw8t
    d3dw8t [OP] Member
    Andrew
    So ended up turning the engine a fraction of an inch and heard it drop, all able to get the scope in further but still don't see it
    Do you guys think I should spin the engine to see if it's stuck since where?
  17. Jun 21, 2018 at 5:27 PM
    1997tacomav6
    Denver
    Did u drain all the oil and look with a longer scope lead?
  18. Jun 21, 2018 at 5:28 PM
    1997tacomav6
    Denver
    Or look from the oil drain plug side instead
  19. Jun 21, 2018 at 5:38 PM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    If you heard it drop, it's probably in the pan, but if this was my truck I would take the oil pan off and start tearing into that engine until I got that washer out.
  20. Jun 21, 2018 at 5:38 PM
    d3dw8t
    d3dw8t [OP] Member
    Andrew
    Yeah oils drained I can't see it, engine spins free
