Help, 2006 Tacoma by automatic transmission
Discussion in 'New Members' started by Clw66, Apr 18, 2019.
  1. Apr 18, 2019 at 6:17 PM
    Clw66
    Clw66 [OP] New Member
    2006 Tacoma
    None
    Decided to change my automatic transmission fluid today, the truck had cooled down for a good 1 1/2 hours and was probably about 100 degrees when I drained it so now the concern and confusion. When I pulled the overflow plug well over 1 quart drained and when I pulled the drain plug aprox 2 quarts drained giving me around 3.2 quarts to replace like my owners manual says and was confirmed at the dealership where I bought the fluid. There are several questions hear. First is why did a quart of fluid drain out of the overflow? I bought this truck brand new and the transmission fluid has never been changed so the amount of fluid in the transmission was from the factory. I am very confused??? Please someone reply. I put the amount of fluid back that I drained. I am a Toyota loyal man and have owned nothing but Toyota's for 25 years now.
    lynyrd3 and irayfz6 like this.
  2. Apr 18, 2019 at 7:26 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
  3. Apr 18, 2019 at 9:41 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
  4. Apr 18, 2019 at 11:17 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Hello @Clw66 welcome to TW! I’ve performed a drain and refill on my 07 a little over a year ago. I experienced the same overflow “drainage,” but I wouldn’t stress over it. Toyota has been known to undermine quality control when it comes to fluid levels in transmissions. Most of the time individuals report that the transmission was LOW by a couple of quarts. My point being is that these transmission can handle a lot of abuse. As long as you’ve followed the proper refilling procedure (slight trickle from overflow), you’ll be alright. My truck had a rough shift from second to third before I performed the drain and refill at 115k. I’m now at 140k and the transmission is smooth as it can be.
    Clw66[OP], lynyrd3 and Taco critter like this.
  5. Apr 19, 2019 at 3:57 AM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Welcome aboard:hattip::cheers:
    Taco critter, Clw66[OP] and irayfz6 like this.
  6. Apr 19, 2019 at 4:17 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Welcome to TW :hattip: @gearcruncher can help !!!
  7. Apr 19, 2019 at 9:12 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
  8. Apr 19, 2019 at 9:22 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    correct me if im wrong, but the over flow is suppose to be checked when the truck is running... and at like 120F.
  9. Apr 20, 2019 at 5:50 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome!
  10. Apr 20, 2019 at 5:57 AM
    lynyrd3
    Bill
    Pretty sure that is correct .
    irayfz6 likes this.
  11. Apr 20, 2019 at 5:57 AM
    lynyrd3
    Bill
    See link in post #2
