Help 2008 immobilizer, Truck keeps getting locked out with no start,
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1997tacomav6, Aug 10, 2016.
  1. Aug 10, 2016 at 8:55 PM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    Need some help from someone I hope.
    I have 1997 Tacoma with 500,000 miles and my brother has a 2008 Tacoma with 75,000 miles.
    Last week on a long trip 500 miles away from home in the middle of no where,
    he was filling up the truck and it wouldn't start.
    Long story short he got the truck to the Toyota dealer and they said it was an immoblizer issue. So they replaced the
    ECU,
    replaced the immobilizer,
    new key, and
    rewired the bypassing wiring harness all for 2500.00
    So the truck was running great and started just fine.
    Now 2 weeks later the truck wount start again.
    It starts sometimes and then other times will not start.
    What in the world to do now??? Is there a way to bypass the whole immoblizer system,
    Any advice please
  2. Aug 11, 2016 at 2:11 PM
    LunaticConcepts
    LunaticConcepts Well-Known Member
    Georgetown, TX
    2015 Tacoma TSS
    TC LT, Kings, OME, Billies, ARB, stuff
    I doubt you could bypass it, but since he just had all that work done, take it back and have them fix it.
  3. Aug 11, 2016 at 2:26 PM
    1997tacomav6
    Denver
    The dealership that did the first attempt was on his vaction route 500 miles away and had it for 5 days trying to figure out the problem.
    Its now at another Toyota dealership by his house and they are looking at it starting with 175.00
    diagnostic test on top of the 2500 already paid to the other Toyota dealership.
    What a disaster Toyota has created in these Tacoma's with the immobilizer's and has only 75,000 miles. They take no responsibility and are happy to charge 2500
    for the repair that still did not fix the problem
  4. Aug 11, 2016 at 4:31 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I had the same problem in my 08. It does not sound like the immobilizer. If it is the immobilizer, the truck will start, run for about 2 seconds and then shuts down. This happens when the code that is sent to the immobilizer is not correct. If the truck starts sometime then the keys, and the immobilizer is not the problem. In my case it was the transponder amplifier that sends the code to the immobilizer. Sometimes it would send the code to the immobilizer and the truck would start, sometimes it would not send the code and the truck failed to start. All the truck would do is crank, like if you were trying to start it with the valet key. The transponder amplifier was $384.42. Toyota told me the same thing, no guarantees this would fix the problem, just their best guest. So far it has been about 3 weeks and almost 200 starts. So far so good. Let me know if you have any questions, I will be glad to give you any help I can. I went through this and it is a very helpless situation. One thing with me is, until the part was replaced the truck not starting was happening move often than not.
    adamsson00 likes this.
  5. Aug 11, 2016 at 6:55 PM
    1997tacomav6
    Denver
    Ok excellent, I will try that route now with the dealership, thanks
  6. Aug 11, 2016 at 7:28 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Are you referring to the black ring electronic piece that fits around the ignition? If that was the case I hope that $384 was not just for that part, it's only like a $110 piece.
    And @1997tacomav6 IF you do go the route to replace the transponder amplifier piece that goes around the ignition it is super easy to do yourself. Just order the part for the $100 or so and its simple remove steering column plastic cover and then plug n play. This should be the correct part number but you should double check: 8978304010
  7. Aug 11, 2016 at 7:30 PM
    1997tacomav6
    Denver
    No that's the antenna for 110.00, immobilizer CPU is 380.00. It could be either part that's no good
  8. Aug 11, 2016 at 7:39 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    I was referring to Larry calling it a "transponder amplifier" which is the "antenna" piece around the ignition.
    Hopefully it's the cheaper part that is the problem :)
  9. Aug 11, 2016 at 8:43 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  10. Aug 12, 2016 at 8:33 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    The transponder amplifier part number is 89780-04011. This is a square computer assy. module that plugs in behind the gauge cluster on my truck. The gauge cluster has to come out to get to the module. Then it is a simple unplug the old module and plug in the new one. Toyota says it is very rare that this module goes bad but they have seen it happen. The dealer had to order the part, there were 5 or 6 available and they were all on the west coast. This was right before July 4th so with the Holiday it took 7 or 8 days for the dealer to get it. Replacing this module was a suggestion made by the Toyota Tech helpline the dealers use when they are stumped.
  11. Nov 18, 2016 at 1:07 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    John, would like to know how you made out on your problem.
  12. Nov 18, 2016 at 2:00 PM
    1997tacomav6
    Denver
    Hello, is my brothers truck and Corporate Toyota has stepped in to try and figure out the problem
    as evey part has been replaced and the truck still will not start, has been thru 2 Toyota dealers
    and neither dealer can find the problem
  13. Nov 18, 2016 at 3:12 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Have you been without the truck all this time? I would think if they cannot find the problem they would be replacing the truck. Usually the harder the problem to identify the easier it its to fix. Good luck.
  14. Nov 18, 2016 at 3:13 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Appreciate the update. Thanks
  15. Nov 18, 2016 at 3:31 PM
    1997tacomav6
    Denver
    Thanks, nope, there are no warranties, and neither of the 2 Toyota dealer wants anything to do with this problem, this truck,
    as they both have spent hours and hours with no results, So files a claim with CORPERATE TOYOTA
    and still waiting for a Toyota engineer to come inspect the truck while the truck just sits.
    I'm glad my 1997 Tacoma is before the imbolizer, :)
  16. Nov 18, 2016 at 4:44 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Ran into the same problem with the 2 Toyota dealers I had to deal with. They are not very good at figuring out the problem. In the end they made a lucky guess and it fixed the problem. Have close to 1000 starts since I got it back.
  17. Nov 18, 2016 at 5:50 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    It would be helpful if you posted what it was that they fixed.
  18. Nov 19, 2016 at 5:11 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    TRD Larry, Aug 12, 2016 Edit Delete Report
  19. Nov 20, 2016 at 8:13 PM
    1997tacomav6
    Denver
    Evey part that has to deal with the immoblizer was replaced and still the imbolizer system is not working
    At 2500 for parts and labor It's a good piece of lawn art right now, 3 months later just sits waiting for
    corporate Toyota to find the problem
  20. Nov 20, 2016 at 8:20 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    This.
    Had the same issue on a piece of shit 2015 Chevy Camaro. Try this. Yeah...I know.. :anonymous:
