Help ,2012 base 4x4 crew cab problems!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Matell, May 31, 2017.
  1. May 31, 2017 at 8:00 PM
    Matell
    Matell [OP] New Member
    2012 Tacoma 4x4 crew cab
    None
    Toyota has just installed a new Transmission after 8 trips to the dealer. The problem was at 60 and 80 K that's Canada,' the truck would shutter,when stepping on gas.Shutter is my word but you could feel the truck hesitating. Got it back from the dealer with new tranny on 5.26.2017 guess what same problem!! Any thoughts out there? I know I have a fight on my hands. Thanks for any help
  2. May 31, 2017 at 8:01 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Take it back
    gersus likes this.
  3. May 31, 2017 at 8:04 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Torque converter?
  4. Jun 1, 2017 at 7:59 AM
    Matell
    None
    No torque converter replaced also
  5. Jun 1, 2017 at 8:15 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    weak leaf spring making axle wrap
    carrier bearing off center
    worn ujoint
    loose pinion shaft bearing
    all of which they should check
  6. Jun 1, 2017 at 8:18 AM
    Matell
    None
    Toyota service department can't figure out what's wrong. They said they would call other dealerships to see if they had run across this problem. Toyota Canada is on this but no help! Meanwhile I need a working truck.
    Thanks for any help.
  7. Jun 1, 2017 at 2:43 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Well, with all that that has been changed - I'd take a real good look at the Engine. You Said "truck would shutter,when stepping on gas." Why did they change the transmission ??? I'm thinking gas pump, fuel filter, last time tuned up (Wires, Plugs, Cap etc.). Change Gas Stations + fuel grade. AC Compressor not shutting off on high emgine power demand? Clean the Injectors/Map etc?
  8. Jun 1, 2017 at 6:29 PM
    Matell
    None
    Toyota pluged there lap top into the trans computer as the service manager and me drove around. Toyota Canada tech's decided the trans needed to be replaced. We are at a standstill. I have been a taco
    owner since the Hi Lux but Toyota is ticking me off
