Help!!2014 TRD trans drain and fill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sonny81, Jul 26, 2024.
  1. Jul 26, 2024 at 11:52 PM
    Sonny81
    Sonny81 [OP] Active Member
    Phoenix
    2014 TRD PreRunnerOff-road 2WD Magnetic Grey
    Bilstein 5100 Shocks and Struts 2.5 front Struts 1inch in rear BFGoodrich AT KO2 265/75R16
    Hey Fellas
    Feeling kinda overwhelmed!
    I was rushing an engine oil change and drained my transmission instead! Should’ve been more aware… I know! I got up and did some things and let it drain then when I came back to put the plug in I realized what I did! It drained about 3.25 quarts. Went to O’Reillys and picked up some Dexron VI, it’s what was recommended. Put the same amount in and when I went to check the the fluid level by taking the over flow plug out, with the engine running, nothing came out. Filled it up some more and nothing. Did this a few times and still wasn’t getting any fluid coming out like it should, the slow stream or the drip, so I added more and nothing. While the engine was running i took the filler plug off and the over flow plug and started filling it until I finally got the fluid to come out and waited until I got the steady stream and then the drip. This put me at 4.5 quarts. Could I have been that low on transmission fluid that it needed that much before I finally got the fluid to start coming out? Took the truck for a test drive and it ran smooth with no problems. Is this the calm before the storm or should I be alright? Thanks for any help!
  2. Jul 27, 2024 at 1:56 AM
    Clearwater Bill
    Billy
    Largo Florida
  3. Jul 27, 2024 at 2:43 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The transmission temperature is important. Suggest taking it to a professional mechanic.
  4. Jul 27, 2024 at 4:10 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Let the truck cool for a few hours since you drove it last and accomplish the fluid level check at the correct temp setting via the link that was posted in this thread.
    It’s not uncommon for transmissions to be underfilled from the factory.
  5. Jul 27, 2024 at 9:01 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Use Valvoline Maxlife or Toyota WS ATF.
    Dexron VI while similar is not for these transmissions.
    nd4spdbh and tacoman45 like this.
  6. Jul 27, 2024 at 10:32 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    May have been low from the factory, Transmission Fluid temp must be 95-115F with the engine running to check the level.
    Uses Toyota WS Fluid.
    ToyotaMan2015 likes this.
  7. Jul 29, 2024 at 3:59 PM
    Sonny81
    Phoenix
    Thanks guys!
    I already did the drain and fill with the Dexron that they suggested. Think I’ll be alright?
  8. Jul 29, 2024 at 4:05 PM
    rnish
    Tacoma 2nd gen
    If it says WS compliant. Probably Yes. I only use MaxLife.
  9. Jul 29, 2024 at 8:03 PM
    2015WhiteOR
    Gainesville TX
    Why did you use Dexron?!
  10. Jul 29, 2024 at 9:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Like stated, if its WS specd you are OK.... otherwise, you ABSOLUTELY need to do a fully drain, and push/flush of proper stuff to get the improper spec'd stuff out.
  11. Jul 30, 2024 at 3:16 PM
    ToyotaMan2015
    ToyotaMan2015 Well-Known Member
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
    I'm glad you mentioned that, the good write up on here still does not have the correct temperature to check the trans fluid
    Dm93[QUOTED] likes this.
  12. Jul 30, 2024 at 3:50 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea several of us have tried to get a mod to fix that or at least add the TSB since the OP of that thread is long gone but so far they have refused.
