HELP! 2016 Tacoma AC not working…
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fishin911, Apr 6, 2023.
  1. Apr 6, 2023 at 10:25 AM
    Fishin911
    Fishin911 [OP] New Member
    Ray
    2016 Tacoma SR5 Silver
    Where do I start… please help me diagnose this issue?
    My AC stopped working. Check the plug powering the blower under the glovebox and noticed the plug was burnt. Replace the blower, plug going to blower, resistor and 10A fuse. Noting! The AC button not lighting up either but the recirculating button works and lights up when pressed. I simply don’t have power. Any thoughts it may be?
    Thanks for your help…
  2. Apr 6, 2023 at 10:27 AM
    Fishin911
    Ray
    Question. Could it be the AC amplifier? In fact, I’m not sure the purpose of this part?
  3. Apr 6, 2023 at 10:28 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Check all fuses and relays first
    wilcam47 likes this.
  4. Apr 6, 2023 at 10:34 AM
    Fishin911
    Ray
    Is there any relays not found next to the battery? Maybe I’m missing one…
  5. Apr 6, 2023 at 1:50 PM
    Fishin911
    Ray
    I just re-check all fuse’s. None blown or bad. I’m going crazy… any thoughts??
  6. Apr 6, 2023 at 2:19 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    You may have to plug in and check some codes to get guidance if power is verified.
  7. Apr 6, 2023 at 2:22 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Stop changing parts. A small leak in your condenser, lines or ports could be the issue. You’re assuming your system is still pressurized. And remember, gas does not disappears, gas escapes. Cheers!
    Chew and 5nahalf like this.
  8. Apr 6, 2023 at 2:26 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Wait, your post while full of info is vague.
    You say the AC stopped working, does the heat work? does the fan work? do the flaps when changing vents work? You say no power, but to where? do the controls work but it doesnt blow cold?
    Chew, hiPSI, Evostaco and 1 other person like this.
  9. Apr 6, 2023 at 3:05 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Swap a part can quickly exceed paying a shop to do it. Diagnose or concede.
    Ricardo13x likes this.
  10. Apr 7, 2023 at 4:25 AM
    caribe makaira
    Caribbean, Puerto Rico
    Did you look at the opposite side of the cable. There are 2 connectors going into the a/c control.
