HELP!! 2019 tacoma turn signal colors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gumbeelee21, Jun 28, 2020.
  1. Jun 28, 2020 at 3:06 PM
    gumbeelee21
    gumbeelee21 [OP] Well-Known Member
    Anthony
    Virginia
    2019 Tacoma Silver Sky OFF ROAD
    Could someone please tell me what colors are the turn signals on a 2019 tacoma
  2. Jun 28, 2020 at 3:11 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    It’s a dark Amber, I had to replace a bulb and now I have two different turn signal colors. It’s annoying cant find the exact color
  3. Jun 28, 2020 at 3:12 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Clear/white lens, orange flash in the mirrors and headlights, red in the back
  4. Jun 28, 2020 at 5:28 PM
    gumbeelee21
    Anthony
    Virginia
    I am talking about the turn signal wire colors, i am a hard wiring a led tailgate bar and for some reason my 4 pin trailer plug in is ot working i can only get running lights and brake signal no turn signals. I plugged the led bar in my other truck and it worked perfect. Was going to try and hardwire into the turn signals see if that would get led bar working? Any ideas what might be wrong with turning lights checked tow fuse amd it was fine. Any help would be greatly appreciated.
  5. Jun 28, 2020 at 11:51 PM
    AKGSD
    Joe
    Alaska
    For science, are you getting the turn signals to the 7 pin?
  6. Jun 29, 2020 at 12:56 AM
    gumbeelee21
    Anthony
    Virginia
    Havnt checked the 7 pin just the 4 pin, and its getting power to the turn signals on the 4 pin checked with a light probe
  7. Jun 29, 2020 at 1:41 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    AKGSD likes this.
  8. Jun 29, 2020 at 2:04 AM
    Yettee
    Yettee Well-Known Member
    Long Beach, CA
    2019 White Tacoma TRD OR 4x4
    The wires you are looking to tap into are the following...
    Driver Side = Yellow (turn signal) and White/Black (ground)
    Passenger Side = Blue (turn signal) and White /Black (ground)
    *these are the wires in the taillights
    The other thinner wires that you see all these YouTOOBERS tapping for LED light bulb swaps are the wrong wires, the ones I listed are the correct ones. If you are wanting to do this through the pin connector then the easiest way to find which ones on there are to get a multi meter and check them one at time while the turn signal is on
    AKGSD likes this.
  9. Jun 29, 2020 at 2:18 AM
    playdixie
    playdixie Miss'ippi fella
    Mississippi
    2016 Blazing Blue TRD Sport DCSB 4x4
    Just a preface: I'm still fairly new about wiring and etc, so please forgive my ignorance/being a noob.
    I have question regarding something somewhat similar. I recently put on a red LED light bar on rear of truck from Rough Country:
    https://www.roughcountry.com/led-tailgate-light-strip-78860.html?find=2016-toyota-tundra-4wd-567150
    It installed no issues and plugged into the 4 prong connector on the rear bumper. However, there is a white wire that runs to the reverse lights to activate the white lights on the LED bar. This is what the instructions reads from their website:
    I would rather run the wire to the 7 pin trailer plug for a "cleaner install. But I'm not sure which wire would be right for that. Also if I were to run it to the tail lights, would you have to know which wire on the reverse lights is the "reverse light positive wire?"
    If you have any insight, I'd greatly appreciate it.
  10. Jun 29, 2020 at 9:35 AM
    gumbeelee21
    Anthony
    Virginia
    i was just going to use the curt tconnector but after that didnt work i actually found the wires in the 7 pin harness via multimeter and tapped into them and got nothing its going to dealership friday its gotta be something wrong with the plug i wire every expensive car audio systems all the time so i am oretty gokd at wiring
