help! 285/70/17 BFG on OEM 17" wheels & coil 2.75" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, Sep 24, 2014.
  1. Sep 24, 2014 at 6:47 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    need advice quick i have a guy selling some almost new BFG 285/70/17 MT for a steel, i have a 2.75" coil lift, OEM UCA's and OEM 17 TRD wheels, anyone know how bad they will rub? my main concern is rubbing on the UCA?
    i cant have much rubbing i need wheel travel, any quick advice very much appreciated he only wants $500!
    thanks in advance
  2. Sep 24, 2014 at 6:49 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    If your worried about rubbing just get some wheel spacers. Thats only a couple hundred bucks so I would go that route especially with that good deal on those tires!
  3. Sep 24, 2014 at 7:54 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    well.. i bought 'em! hope they fit :) if not anyone need tires, LOL!
  4. Sep 24, 2014 at 7:56 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    They'll work with wheel spacers as mentioned. Be prepared to trim some plastic, too.
  5. Sep 24, 2014 at 8:12 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    what size spacers do i need? 1"? i would like to keep spacers to a minimum
    just wondering from peeps who run the same, whats the gas mileage drop? right now i get about 15mpg with oem, i do floor it sometimes, lol, so i know it could be better. but oem run about 40lbs each i think? these would be be closer to 60lbs. not a deal breaker for sure, just wondering.
    these are the tires i bought
    http://www.amazon.com/BFGoodrich-Mud-Terrain-Competition-Tire/dp/B0055BOTJC
    thanks guys!
  6. Sep 24, 2014 at 8:50 PM
    Cjanik
    Cjanik Senior Member
    Chase
    Vegas
    '11 4x4 Off-Road DCSB in MGM
    OME front & rear shocks, OME 886 springs, Dakar rear leaf pack, ICON UCA, Demello front bumper, BFG M/T 255/85r16
    what did you pay?
    yes run wheel spacers, those are awesome tires, dont sell them when you can run them with spacers. (as long as the tire set was a good deal of course)
  7. Sep 24, 2014 at 9:00 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    This is my question as well. I am running 1.25" spidertrax and have a 3" lift. Some have told me that I can, others that I can't. I also have LR UCA's..... I guess that I will just have to try it out when tue time comes. Keep us updated.
  8. Sep 24, 2014 at 11:49 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    i paid $500, only have a couple thousand miles on them, look almost new. so i think good deal. so we will see how it goes :)
    anyone know what size spacers i need?
  9. Sep 25, 2014 at 3:09 AM
    Phils514
    Phils514 Well-Known Member
    Phil
    Dcsb
    1.25 at least
  10. Sep 25, 2014 at 6:58 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Get Spidertrax spacers. They are 1.25" but thats what most people run and have no UCA rubbing issues.
  11. Sep 25, 2014 at 7:10 AM
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
    I'm planning on getting 285s with 18 in. Rim. If I get 1.5" spacers, will they fit with a 3 in. Lift, I know I'll have to trim plastic.
  12. Sep 25, 2014 at 7:13 AM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I have a 3" lift with LR UCA's and no spacers and have no rubbing issues with 285/75/16's. Had the cab mount chop done and trimmed some plastic and have no problems.
  13. Sep 25, 2014 at 7:43 AM
    Fiend13
    Chad
    I ran this setup on my stock O/R wheels, 16" with 5.5 bs and they sat fairly close to the UCA's. I could fit my finger in between the tire and the UCA. I eventually went with a wheel with 4.5" bs cause I plan to run maxtrac spindles at some point.
  14. Sep 25, 2014 at 8:01 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    If you get the right sized wheels you wont need wheel spacers. Try and get it in 4.5" backspacing with a -12mm offset. I have 18"s with 285's with those specs and I just needed to do a little trimming up front and take off the front mud guards.
  15. Sep 25, 2014 at 8:53 AM
    Fiend13
    Chad
    Exactly. But if you get spacers, go with Spidertrax. Based off of members who run them, they are the best spacers to get. I don't know much about them but it's probably because they're hubcentric whereas others are lud centric I think.
  16. Sep 25, 2014 at 10:16 AM
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    I ran 1" Bora spacers for a while with my stock Sport wheels (5.5" bs) & 285/70-17 tires. This is the minimum you need to clear the UCAs. Btw Bora spacers are an awesome product as well. As others have said, 4.5 bs on any wheel is the minimum with wider tires on our trucks.
    I installed LR UCAs and rolled the upper ball joints forward and still got a factory rec. caster adjustment. Doing this, moved my wheel center forward about 1.25" and kept my 285 tires away from the cab mount at full lock/stuff.
    With 285s, any less then 4.5" bs and more width than an 8" wheel on any combo, can cause cab mount rubbing.
    There is a thread on here that details this geometry setup. I'll find it for you and post a link to it.
  17. Sep 25, 2014 at 10:26 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    with aftermarket UCAs I'm not sure. I run the same tire in a 285/75/16 with 1.25 spidertrax and stock wheels and UCAs. Had the same setup with 1 inch spacers and no issues there
  18. Sep 25, 2014 at 10:29 AM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Too much backspacing, you'll rub on the UCA. Not enough backspace or too wide of a wheel, you'll rub on the pinch weld and cab mount. So you need to plan it all out and select carefully. Cutting & trimming isn't a big deal though. It just depends on what you want to do. Or don't want to do. In my case, I was able to setup my front end with no trimming in the rear of my wheel well. And instead of hacking up the front of the wheel well liners, I was able to shove them forward and clear my tires that way.
    Here's that write up on how to setup your front end. I was very fortunate to find this thread before I did my lift. It was very helpful and set me up for success.
    http://www.tacomaworld.com/forum/su...ing-report-light-racing-ucas.html#post3219050
  19. May 27, 2018 at 2:12 PM
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    Very old thread I know, but I have a 2016 Taco that I currently have a 3" lift on. I plan on running BFG K02 285/70/17's, is that similar to what you ran? I would prefer to use a 1" spacer over a 1.25" if possible.
