Help - 2nd Gen 4x4 on snow - which traction control setting?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BaconPower, Jan 17, 2017.
  1. Jan 18, 2017 at 6:42 AM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    You'll only experience engine regulation when taking off from a stop.
    Holding the button down when stopped shuts off all traction control, but not ABS. I like to keep the LSD functioning most of the time that I drive in snow on road - which is nearly half of the year.
  2. Jan 18, 2017 at 6:42 AM
    tgear.shead
    tgear.shead Well-Known Member
    Like I said... for snow plowing. That isn't like just regular driving in a foot of fluff.
  3. Jan 18, 2017 at 6:43 AM
    Pigpen
    Northwest Montana
    4 low works great in deep snow when tires are aired down. You just need to be easy on the throttle.
    Edit: Pic 1 is deep dense snow. Look at the picnic table. The snow is much more than axle deep. Tires are at 12 psi (I think) and the truck is floating on the snow. I crawled in 4 low first gear on a couple miles of deep snow to get to this spot.
    Pic 2 is soft fluffy snow. Tires are not aired down at all to help me reach through to firm ground. 4 high here.
    dziner, Cmurder and wilcam47 like this.
  4. Jan 18, 2017 at 6:53 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    i suppose ill have to experiment more
  5. Jan 18, 2017 at 9:17 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Traction control button, press and hold for at least ten seconds
  6. Jan 18, 2017 at 9:23 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    I wouldn't do that. I'd just push it once quick.
    I've tried starting on snowy hills in mine with traction control completely disabled and it doesn't budge. All the power goes to the wheel with the least grip. If you press it once, you'll get Auto LSD and it'll move power back and forth on the rear axle and you'll have a much better chance of moving.
  7. Jan 18, 2017 at 9:48 AM
    tgear.shead
    Did they change the programming of the skid control ECU at some point?
    For mine, tapping once in 4H does absolutely nothing. Its default state there is TRAC. In 2H, tapping once switches from power regulation to ALSD.
  8. Jan 18, 2017 at 11:05 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    In 4hi when tapping the button once turns of engine power management. The auto LSD doesn't light up in 4wd. The trac off light turns on. Its basically auto LSD in 4wd.
  9. Jan 18, 2017 at 11:09 AM
    tgear.shead
    There's no engine power management in 4WD ever on mine. They must have added that to a newer MY.
  10. Jan 18, 2017 at 12:52 PM
    Skunny
    Skunny Member
    Ken
    Redlands
    2014 4x4 TRD Sport DBC
    What about for Sport? I have 4x4 Sport 2014. I haven't disabled anything yet while driving in snow in 4hi. Everything seems ok except for when the ABS kicks in.
  11. Jan 18, 2017 at 1:00 PM
    moondeath
    Pa, Gardners
    They changed certain nanny systems over the years. Earlier years didn't even have the vehicle stability nanny systems. 09, I believe is when auto LSD was added.
  12. Jan 18, 2017 at 1:27 PM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Your tires are the problem. The stock Ruggedfails are barely adequate on wet pavement, let alone severe weather. On your next set of tires look for something with the Mountain Snowflake symbol on the sidewall indicating it's severe weather rated. Besides having excellent traction you also get the benefit of not being required to run chains during chain restrictions.
    I'm running BFG KO2's in the shit show that has been the Columbia Gorge for the last 6 weeks. No issues at all getting around and we've had it far worse than Portland.
    ETA: I have a TRD Sport. I generally turn the traction control off in this weather.
