*HELP* 2nd Gen factory HU wiring diagram!
Discussion in 'Audio & Video' started by DylansBase, May 2, 2013.
  1. May 2, 2013 at 11:17 PM
    DylansBase
    DylansBase [OP] Well-Known Member
    Dylan
    Sacramento
    2002 T4R SuperCharged Limited 4x4
    3" rouch country suspension lift Extended roof basket D2S mini 3.0 Retrofit Addicted Offroad Tube bumper BAMF Sliders w/kickout 16" Procomp 7039 series Aftermarket audio CB in ashtray
    Im looking to install a module with the end result of adding and amp/subwoofers. The module itself is not color coded although i do have instructions for what connects to what. All I need is a accurate wire diagram of the stock harness itself. If anyone comes across one and is able to post it, it would be greatly appreciated!
  2. May 6, 2013 at 1:30 PM
    RubberDucky
    RubberDucky Well-Known Member
    Dillon
    North Pole, AK
    2010 Sport SR5 LB
    Stereo install.
    http://www.tacomaworld.com/forum/audio-video/261506-2012-wiring-harness-diagram.html
    There are a few online... This is from that post:
    2012 radio and speaker wires (not with jbl)
    - all wires are found behind the radio
    radio 12v- light blue
    radio ground- brown
    radio turn on/ignition- gray
    radio ilumination- green(park lights)-- green w/ white stripe(dimmer)
    -speakers
    driver front speaker-pink (+)-- purple (-)
    passenger front speaker- light green (+)-- blue(-)
    driver rear speaker- black (+)-- yellow(-)
    passenger rear speaker- red(+)-- white(-)
  3. May 7, 2013 at 4:02 PM
    DylansBase
    Dylan
    Sacramento
    Awesome! Helps alot!
  4. May 8, 2013 at 7:50 AM
    mr2snob
    mr2snob Member
    Chad
    Cincinnati, Ohio
    13 4x4 SR5 Manual
    Sub'ed. Looking at a self powered bass box and will need the remote turn on and speaker wire colors.
  5. May 8, 2013 at 10:42 AM
    RubberDucky
    Dillon
    North Pole, AK
    2010 Sport SR5 LB
    Stereo install.
    I was trying to post a question about this as well. I am having issues using the "Gray" wire for my remote turn on. I have an Amp and an Equalizer I want to receive power when my truck is on and to automatically shut off when the truck is off. Right now they get constant power and I've got them hooked up to a switch that I manually shut off. I fear leaving it on and killing my battery. I know it will happen sooner or later.
    I will keep searching for some other sources and better detailed diagrams. I highly recommend The12Volt.com for a lot of this type of info.
    (I have not confirmed any info I am providing, just results from my Googling)
    Additional Links:
    http://stereowiringdiagram.info/2010-toyota-tacoma/
