Help: 2ohm or 4ohm IDQv3 10" for alpine pdx5
Discussion in 'Audio & Video' started by acozzens, Apr 20, 2009.
2 or 4 ohm version of the idqv3 10" is right for my setup?
Poll closed Apr 27, 2009.
  1. 2 ohm
    3 vote(s)
    42.9%
  2. 4 ohm
    4 vote(s)
    57.1%
  3. PDX5 isn't enough juice for x2 idq 10"
    0 vote(s)
    0.0%
  1. Apr 20, 2009 at 9:21 PM
    acozzens
    acozzens [OP] Well-Known Member
    98056 , washington state
    06 4d 4wd trd sr5 silver
    Michelin ltx m/s WSU (cougs) License Plate Holder $1.99 Gate Theft Mod DIY HU install DIY SWI-JACK install DIY rear speaker & baffle DIY ipod audio/video interface DIY HD radio DIY Alpine pdx 5 DIY front components install DIY RedLine Tuning Gas hood lift ( very slick ) DIY slimcubby gb hid head/fog DIY extang trifold trifecta DIY dynolock tailgate lock
    I'm trying to figure out the specific sub to get:
    2ohm or 4ohm IDQv3 10" for my amp alpine pdx5
    I'm only going to install 1 amp, and the pdx5 is it..
    I'm considering a box from Mr Marv,
    or the Super Crew Sound to save some $ as I really want a tonneau cover and motorcycle trailer...
    After talking with marv and researching, the idqv3 seems like it will do quite well.
    I'm definitely buying at least one. But i'm not sure if I'll want a 2nd later. if I do want to potentially upgrade later ( if a single 10 doesn't sound like I want ) which ohm sub should I get ? 2 or 4 ?
    IDQ10V3.D4 - Image Dynamics 10" IDQ Version 3 Subwoofer
    or
    IDQ10V3.D2 - Image Dynamics 10" IDQ Version 3 Subwoofer
    I have read up on ohm talk, but i'm not confident enough to pull the trigger as I really don't want to have to send it back for my ignorance.
    The PDX 5 says it can put out 300w at 2 or 4 ohm so I feel like I have choices.
    My thinking here is that if I want to add a 2nd subwoofer later, then either the 2 or 4 ohm version of this speaker is 'correct'
    thanks,
    Aaron
  2. Apr 20, 2009 at 9:45 PM
    Mexican_taco
    Mexican_taco Well-Known Member
    Oxnard, CA
    07 Toyota PreRunner
    painted black rims, fog light mod. debadged
    4 ohms with the correct wiring will give you a deeper sound.
  3. Apr 20, 2009 at 9:48 PM
    acozzens
    Thanks MTaco
    And with a 4 ohm speaker, could I buy another 4 ohm speaker if I wanted a second sub ? or is that a waste with a pdx 5's sub channel ?
    I had an RF punch 200x1 mono that I used to power 2 12"s in my old vehicle and it pushed 'em pretty well.
  4. Apr 21, 2009 at 4:54 AM
    elephatitis
    elephatitis Member
    It does not matter if you get the dual 4's or the dual 2's. Your amp is rated to push 300 watts on a 4 or 2 ohm load.
    The reason why subs have dual voice coils is due to its wiring flexibility not to make the "sound deeper."
    If you wanna add a sub later on, then get dual 2's. You can wire each sub in series then parallel them together to get a 2ohm load.
  5. Apr 21, 2009 at 7:57 AM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    huh? :rolleyes:
  6. Apr 21, 2009 at 8:54 AM
    acozzens
    That's what I was looking for... I knew I had some wiring options.. From my quick kreading I knew i could double or halve the ohm load based on the wiring..
  7. Apr 21, 2009 at 9:49 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    I agree with elephatitis and if you even think you may add another sub later I would suggest getting a different amp that doubles power at 2 ohms (you will get a theoretical 6 db increase in output by doubling power as well as cone area. :))
  8. Apr 21, 2009 at 9:53 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    There's only one other thing to really note, the PDX series amps do a strange thing in that they treat 2Ω and 4Ω loads the same, so you don't need to worry as much.
    However, if you were to replace the amp with something more traditional, I would keep with the 2Ω versions. Traditional amps care more about the ohm load, and will allow you to reach different wattages as a result.
    Also, speaking to another guy here, he said that the PDX might be a little light on power. See if you can listen to a setup, or get some more advice regarding this.
  9. Apr 21, 2009 at 1:05 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I agree with Chjinckenmunga that with 2ohms you will be able to run them on more amps with the sound you want.
    Why are you going with IQs anyway?
    P3s in the supercrew is what I'm running and it slams pretty good. Those IQ 3s in that box gotta be super tight.
  10. Apr 21, 2009 at 1:46 PM
    acozzens
    thanks everyone..
    Dave: going with IDQ's because I'm sure they're at least a decent sub.
    I got tired of researching online, in general car speakers are fairly tough to research. There is not a good spot to "go listen to stereo setups in 4d 06 tacoma's" and 'sound rooms' inside stores are not apples-apples with a truck cab. So I rely on reviews/tech summaries of others.
    Basically, i'm convinced that my ideas here will not result in a shit-sandwhich system.
  11. Apr 21, 2009 at 1:50 PM
    Mr Marv
    Marv
    Definitely a lot better than "decent" IMO! :)
  12. Apr 21, 2009 at 1:57 PM
    atsaubrey
    california
    IDQ's consistantly bring me home trophies.
  13. Apr 22, 2009 at 2:28 AM
    acozzens
  14. Apr 22, 2009 at 7:34 AM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I just got the PDX-5 amp and the Image Dynamics IDQ 10" in 4 ohm...I haven't installed the sub or amp but don't let the small amp fool you. My birthsheet from Alpine for the amp is rated at 105w x 4 and 424w x 1.
    Have you got your PDX-5? I know a Ebay store that sells them for $365/shipped out of Florida. Great store to deal with.
  15. Apr 22, 2009 at 11:55 AM
    acozzens
    thanks for the further confidence guys.
    Yeah I already have the pdx.. basically just found lowest price with at least decent vendor reviews from ebay. It was fairly close to your price....
    As far as the box, i'm still thinking. Mr Marv wants to make his presence felt in the Seattle area I think. But I'm still trying to shave some $$ because I want several new options for my truck... ( like racks/tonneau/trailer ) and that shit gets expensive.
  16. Apr 25, 2009 at 7:22 AM
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    i've had my pdx-5 for over a year now and let me tell you that i am still suprised by it. it is powering type components, type-r coax's, and a jl stealthbox. it is not crazy loud but it is perfect for what i want.
