Help! 3.4 L Supercharger install - hose questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by desert-rat, Mar 31, 2019.
  1. Mar 31, 2019 at 11:00 AM
    desert-rat
    desert-rat [OP] Well-Known Member
    somewhere in Utah
    2001 Tacoma Limited TRD SC DC
    Hey everyone. I need a little help identifying a couple hoses left over after installing the supercharger. I’m not sure where they should go.
    There are two hose barbs in the driver side of the supercharger left over (see green square in photo below). Coincidentally I have two hoses also left over that need to be connected but I don’t want to make any assumptions here. Hose1 (yellow marks in photo) comes from some valve thing next to the evaporative canister I think. Hose2 (red marks in photo) seems to come from the brake booster behind the master cylinder.
    Before I installed the supercharger I took some pictures. Below you can see hose1 from the valve was connected to the top of the intake manifold.
    Before installing the supercharger, hose2 was connected to the lower plenum of the intake manifold.
    Any help would be appreciated! I’m so close to being done - it was a big job.
  2. Apr 1, 2019 at 8:23 AM
    1997tacomav6
    Denver
    Here are the instructions
    http://www.lcengineering.com/LCInstructions/89-89-34-003_Rev1_Toyota_34_Magnuson.pdf
    Area51Runner likes this.
  3. Apr 1, 2019 at 8:39 AM
    00_5VZ
    00_5VZ Dumbest smart guy you’ll ever meet
    Rob
    Thornton, CO
    2004 DC TRD, S/C, Impulse Red Pearl
    TRD S/C, URD 7th injector, Deck plate mod, gray wire mod, 2 low mod, magnaflow cat back exhaust
    Hoses 1 and 2 attach to those blank ports, and that’s the easy part. Did you get the TRD supercharger specific throttlebody gasket or the one way check valve for the IAC hose?
    1997tacomav6 likes this.
  4. Apr 1, 2019 at 8:49 AM
    00_5VZ
    Rob
    Thornton, CO
    Cause those ports are before the rotor assembly, so it’s always under vacuum
  5. Apr 1, 2019 at 7:43 PM
    desert-rat
    somewhere in Utah
    Thanks! I was missing the pages with the diagrams, which your link had. So the two hoses connect, but not to the ports I would have guessed. Glad I asked for help!
    Yes, I got the right gasket - without it you lose like 1.5lb of boost! The instructions I had said you don't need the 1 way check valve for 2001 or newer, which mine is, so I didn't use it.
    Gave it a start tonight and drove it. Quite a bit more power! Thank you to all who responded. :) Great forum!
    1997tacomav6[QUOTED] likes this.
  6. Apr 2, 2019 at 5:24 AM
    00_5VZ
    Rob
    Thornton, CO
    Are you sure about the one way check valve? Does your truck have the ETCS throttlebody? If it does your right you don’t need it, if it doesn’t you need to get it
  7. Apr 2, 2019 at 5:58 PM
    desert-rat
    somewhere in Utah
    I must admit, I wouldn't know an ETCS throttle body if a winning lottery ticket was attached to it. How can I identify the difference?
  8. Apr 2, 2019 at 6:04 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Drive by wire or drive by cable
  9. Apr 2, 2019 at 6:55 PM
    1997tacomav6
    Denver
