!HELP! 31"s on my tacoma drifting to the right.
Discussion in '5 Lug' started by lnfravor, Jul 15, 2019.
  1. Jul 15, 2019 at 5:21 AM
    lnfravor
    lnfravor [OP] Active Member
    logan
    2008 2.7L White Tacoma
    3" lift on 31's with bart d trucker wheels
    Just put 31"s on my 2008 Tacoma 2.7L with a 3 " lift. Had to buy wheel spacers to clear the calipers. I found out after the lift was installed with the tires that the truck vibrates like crazy, which isn't a big deal but it veers to the right ALOT. I can be at a stop sign and let off the gas a little and the steering wheel turns 180 degrees to the right while the tires are straight. My dad thinks its because of a loose A-arm or Ball Joint. Any suggestion or help would be great.
  2. Jul 15, 2019 at 5:39 AM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    OP,
    You need to get the nose up, remove the spacers and recheck, while you are underneath do the pry and shake tests look for anything moving more than a couple of mm.
    Since it started after the “modification” remove all of that and test again...
    First rule of working on modified vehicles, remove/disconnect mods then diagnose. (If possible)
  3. Jul 18, 2019 at 7:15 PM
    Steven07
    Steven07 Well-Known Member
    Steven
    2017 Gray SR5 Tacoma
    3in front lift, 2.5 rear lift
    I am having the exact same problem. I've tried 8 things to fox it but nothing has worked. Some of them actually helped but it still does it.
  4. Sep 18, 2019 at 7:27 AM
    lnfravor
    logan
    I’ve narrowed it down to maybe calipers or struts. If a caliper wasn’t gripping right would that cause the pull to the right. If the right one is grabbing and the left one isn’t. Or could have a bad right strut? I’m still stumped on this one!
  5. Sep 18, 2019 at 7:39 AM
    Steven07
    Steven
    Does it only veer to the right when you hit the breaks?
  6. Sep 18, 2019 at 7:45 AM
    lnfravor
    logan
    Yes. It drifts right a little driving straight but that’s do to the tires. But it’s the worst when I hit the brakes
  7. Sep 18, 2019 at 7:49 AM
    Steven07
    Steven
    Sounds like an alignment problem to me. If it still drifts to the when driving. Plus the vibration might be analignment problem
  8. Sep 18, 2019 at 7:53 AM
    lnfravor
    logan
    I’ve had the alignment done three times. And it still did it after every alignment. I’m baffled on what it would be.
  9. Sep 18, 2019 at 7:54 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Are they cheap tires?
  10. Sep 18, 2019 at 7:58 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Def check alignment but if its pulling hard when breaking you could have a seized piston in your calipers. this can cause the truck to shift on way or the other depending on which side. Old calipers or added new ones recently? I rebuilt a set not that long ago after I had a similar issue. Dust seals were shot and at least one piston was not moving well.
  11. Sep 18, 2019 at 8:01 AM
    Steven07
    Steven
    Mine drifts to the right all the time no matter if I break or not. It also vibrates all the time. But I have the alignment done every week since this problem has occurred.
  12. Sep 18, 2019 at 9:06 AM
    lnfravor
    logan
    Hey are kumhos which we’re great on my 4Runner I had. They cost about 500 for all four
  13. Sep 23, 2019 at 4:20 PM
    MJsolo
    MJsolo Member
    MJ
    2005 White 5 lug Tacoma
    Readylift 2.75" spacer in the front, running 31x10.50R15LT's, FatBobs AAL
    with the alignment, they will set it to naturally be off a little on one side just to compensate for road crown, I would try and get my tires balanced
  14. Sep 25, 2019 at 4:18 PM
    zztaco
    zztaco Member
    FL
    1st gen 5 lug
    I had similar issue. One of the front calipers was always dragging. I had to tighten up the adjustment nut on the master cylinder pushrod a teeny bit to get it to stop
