Help: 3rd Gen CBI Hidden Winch Mount
Discussion in 'Technical Chat' started by camdz, Sep 30, 2017.
  1. Sep 30, 2017 at 1:41 PM
    camdz
    camdz [OP] Well-Known Member
    Kansas City
    2017 TRD Sport DCSB
    I have emailed @CBI Offroad Fab but they are closed this weekend, so I doubt I get a response.
    This mount did not come with instructions, and I cannot find any anywhere. If I missed them somewhere, I blame the alcohol consumed last night.
    My bumper is removed, aluminum "crash bumper" removed, holes on the mount line up perfectly but you cannot slide the mount back far enough to reach the frame studs. The lower radiator support is in the way. The mount came with two arms that I'm clueless on where to put.
    Ive installed many bumpers on toyota trucks, but for some reason I'm stuck. Has anyone installed these before or know where I can get instructions?
    Here are a few pics of what I'm working with.
  2. Sep 30, 2017 at 1:46 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    camdz[OP] likes this.
  3. Sep 30, 2017 at 1:48 PM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    have you tried removing the crash bar end caps (same hardware as tow hook)? also make sure you're not trying to install it upside down.
  4. Sep 30, 2017 at 1:55 PM
    camdz
    Kansas City
    2017 TRD Sport DCSB
    I did not think of that. Its definitely not being installed upside down. To be honest I didnt know the end caps even came off. Whats the point of having them?
    If thats the case, Ill be able to get the mount into the frame studs. Then Ill just to figure out what these crazy looking arms are for, and why there are so many holes in them.
  5. Sep 30, 2017 at 2:13 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    Those arms are frame supports. 2 holes where the sway bar connects, 1 on the side of the frame, and the last 2 on the bumper. They are easy to figure out once you know where they go. Just follow those instructions and you'll have your bumper on sooner than you know it.
    camdz[QUOTED][OP] likes this.
  6. Sep 30, 2017 at 3:47 PM
    camdz
    Kansas City
    2017 TRD Sport DCSB
    Thanks everyone for the help. Not sure why I didn't think to look at other CBI bumper installs. I should have mentioned the Toyota trucks I've always worked on were FJs and 4th gen 4runners. So the brackets and power steering cooler/line relocation brackets were foreign to me!
    The mount is on, and I'm taking a break to go have dinner with the inlaws. I will finish up with the support arms tonight.
    90yota likes this.
  7. Sep 30, 2017 at 3:56 PM
    camdz
    Kansas City
    2017 TRD Sport DCSB
    I will note that CBI did not send me any smaller hardware for the other end of the power steering relocation brackets. I followed the instructions in the above link, and just used a nut/bolt combo that I had in the garage. I'm assuming it was done correctly. As you can see in the image in the opening post, I only received bolts that were too large to fit through that bracket.
    It wouldnt be a garage install though if it didnt require a little creativity or me breaking something.
    90yota likes this.
  8. May 7, 2022 at 8:28 PM
    LP808
    LP808 Well-Known Member
    2016 Base SR5 Tacoma
    None
    Anyone know how big exactly the hole needs to be in your bumper valance? It seems the front of the bumper protrudes out so I can't lock it back in completely. I don't wanna cut it too big either. Any help will do
