Help, 50mph shudder?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaNewb, May 14, 2010.
  1. May 14, 2010 at 2:32 AM
    TacomaNewb
    TacomaNewb [OP] Member
    Brian
    Washington State
    03 4x4 SR5 TRD V6
    I was driving home from work last night and once I got to 50mph on the highway my 03 taco started to shudder. I flipped the electronic transmission switch and it would go past 50 without a shudder, anyone got any ideas??? I'm taking it into a shop to have it looked at in the next couple days and it makes me nervous to drive it like that but it's my only transportation, looks like back roads for me till I figure it out haha
  2. May 14, 2010 at 6:53 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    At 50 with ECT on Normal, it shifts into 4th. It sounds like your truck is not making as much power as it should, and when it shifts into 4th at such a low RPM/speed, it is realy struggling. I would try the basic performance enhancing maintenance:
    -First, make sure you are using high quality gas
    -Seafoam your engine
    -Seafoam in your Gas tank (clean injectors)
    -Check fuel filter
    -Replace spark plugs if needed. Stock plugs are usually 30k miles
    -Clean MAF
    If this doesnt help, try a toyota dealer. It might be more $$$, but they usually offer the best help (in my experience at least).
  3. May 14, 2010 at 6:55 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Post what the dealer finds if you would. Could be helpful for all if it ever starts for us.
  4. May 14, 2010 at 7:45 PM
    DigB
    DigB Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Is Seafoam just an injector cleaner? what would you use it on, specifically, aside from putting some in the gas tank?
  5. May 14, 2010 at 7:58 PM
    HerNameIsLucy
    RIP Lucy.
  6. May 15, 2010 at 7:05 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  7. May 15, 2010 at 7:12 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Not discounting any previous suggestions, but if it only happened that one time, I would experiment and make sure it doesn't happen every time you hover around the 50 mph mark (or any other specific speed) regardless of the other criteria.
    It very well could be that you just lost a wheel weight or picked up some mud in one or more of the wheels, throwing the wheel/tire balance off.
