Help: 6mm hubcentric rings, where?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Jun 30, 2012.
  1. Jun 30, 2012 at 11:10 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    i've got Black Rhino Imperial wheels. They're 112 bore and our trucks are 106. I'm having a hard time finding some hubcentric rings that are able to fit the gap of 6mm.
    Help. Thanks.
  2. Jul 1, 2012 at 10:14 PM
    tacomtn
    Anyone??!!
  3. Jul 2, 2012 at 8:43 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    First of all, are you sure about the 112mm center bore? Reason I asked is because that is not a very common center bore size. Most wheels made to fit multiple trucks are going to be 110mm center bore. 1010tire.com sells just about every hub ring imaginable and they don't even list a 112.
  4. Jul 2, 2012 at 9:00 AM
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    Link to black rhino site, bore shows 112
    http://www.blackrhinowheels.com/off-road-wheels-rims-ocotillo.php
  5. Jul 2, 2012 at 10:13 AM
    Bama_TACO
    Winfield, AL
    I'm at a loss. I'm usually pretty good at finding things. I have looked the internet over and I can't find a 112mm hub centric ring.
  6. Jul 2, 2012 at 10:22 AM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    They do not have 112mm in their list but they can make them for you.
    They go all the way up to 160mm where as most stop at 110mm from what I am looking at.
    http://www.motorsport-tech.com/4DCGI/h_yearmakemodel.html
    They do all different type of custom work and recently did a group buy for wheels spacers for us at tacoma world.
    Sent them a email or call them with your needs and they will set you up. They make them in plastic or aluminum.
    http://www.motorsport-tech.com/4DCGI/hub_rings_select.html
  7. Jul 2, 2012 at 11:16 AM
    tacomtn
    Thanks for this info. I called them and they want $100 plus $15 (after I inquired about the inflated shipping from $25) for 4 rings!!! Wow. That's a very high price and their price gouging, including on the inflated shipping. But if they're the only ones that are willing to make that size then I don't have much choice. The dude I spoke with wasnt the friendliest either. I'd rather go somewhere else if possible.
    I'll search more. There's got to be someone out there w/o price gouging
  8. Jul 2, 2012 at 11:27 AM
    lj973gm
    Ohio
    06 DCSB 4wd
  9. Jul 3, 2012 at 1:36 PM
    tacomtn
    Awesome. Thanks for researching for me. I should have called Discount Tires first since I bought them there. They're going to send me some rings for this application. Great customer service. Hopefully these will fit and do the trick. I'll keep posted here to help others out.
    Again thanks so much for researching!
  10. Jul 7, 2012 at 8:06 AM
    ApacheDriver
    ApacheDriver Showin' HAWG how it's done!
    Zach
    Phoenix
    '10 MGM DCSB TRD Sport 4x4
    ICON, Black Rhino Imperial 17x9, 285/70 BFG A/T, ToughLite 32” light bar, weather tech, wet okole (rear)
    Just ordered a set of 17x9 Imperials. Hopefully they are sending rings too! Forgot to ask :eek:
  11. Jul 7, 2012 at 5:50 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    checked gorilla-auto.com too and no luck
  12. Jul 17, 2012 at 2:13 PM
    Twiostaco
    Austin
    Utah
    Any update? Wondering if this works so i can call discount for these rings
  13. Jul 17, 2012 at 2:17 PM
    mseymour3
    mseymour3 Well-Known Member
    Michael
    Tennessee
  14. Jul 17, 2012 at 3:31 PM
    Wolfbite
    Wolfbite New Member
    Justin
    Oklahoma
    White DC SB 4x4 TRD O.R.
    Debadged, Black Westin 3" steps, Black Westin Ultimate Bull Bar, Two 6" Westin offroad lights. Future endeavors.... Leather seats, TRD intake, TRD exhaust, Black Rhino Sidewinder 17x9" wheels w/ 265/65r17 Hankook Dynapro ATm tires, front Bilstein 5100 height adjustable coil-overs set to 3", rear 2" AAL w/ bilstein 5100 shocks.
    Www.Hubcentric-rings.com will make polycarbonate rings in any size, just give them the I.D. and O.D. and your good to go. Prices are a little lower, though they are out of Finland and prices are in euros. But they do ship here anyway. I'm looking at getting the Black Rhino Sidewinder's with 265/65r17 dynapro ATM's myself. Though personally I'll prolly end up spending the extra for aluminum rings.
  15. Jul 18, 2012 at 12:15 PM
    tacomtn
    I put on the rings and there still some wobble. Not as bad but still there. I'm wondering what's going on!!!
    The rings came from TSW, distributor for Black Rhino. No charge through Discount Tires
  16. Aug 7, 2017 at 3:27 PM
    NosikaTay
    NosikaTay Member
    2015 Mag Grey Dbl Can 4x4 Base
    3" Toytec lift/17" Blk Rhino wheels and 265/70 17r Nitto Terra Grapler G2
    Wanted to see if there was any resolution to the hub ring find? I bought Black Rhino Warlords and the Hub bore is 112mm. Our trucks have a bore of 106mm. So where do we get our rings from? Did you go to hub rings.com and get them specially made for you? I am waiting to hear back from Discount Tire Direct with news and help.
    Thanks!
