Help!!! 885s or 884s for Acces Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by renval, Mar 25, 2009.
  1. Mar 25, 2009 at 7:38 PM
    renval
    renval [OP] Well-Known Member
    Renz
    SoCal
    Hi guys hopefuly u can help me, im a proud owner of a 2006 4x4 TRD Tacoma Access Cab, im getting differents opinions about what coils to get:( i would like to get the 3'' Toytec lift coils for the front and AAL leafs for the rear, i want to make my decision soon so i can move foward with this THX 4 ur time:)
  2. Mar 25, 2009 at 7:43 PM
    ghostboy808
    ghostboy808 Well-Known Member
    Silver Mica Prerunner TRD Sport
    Gibson SS, TRD S/C
    same spring rate between the two, 885 is 10mm longer
  3. Mar 25, 2009 at 7:53 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    884's are for access cabs. 885's like mine are for double cabs. Unless you will be putting a bumper and or winch in the front get the 884's. 885's will also be stiffer on your truck.
  4. Mar 25, 2009 at 7:57 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    DING DING! and i'm sure we can get an AMEN from chris on this too
  5. Mar 25, 2009 at 10:35 PM
    renval
    Renz
    SoCal
    but the 884s will sag eventually, can i fix that adding a thicker top plate, im on a budget and cant get better shocks right now:eek:
  6. Mar 26, 2009 at 3:42 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yes...You can add a top plate spacer to the 884's. I just ordered 885s for my access cab (planning on skids/sliders and maybe a bumper) and I got 1/2" spacers to go with it just in case.
    You will be much happier if you do it with the right shocks tho...Waiting a bit longer until you do have the money for that might be worth it.
  7. Mar 26, 2009 at 12:43 PM
    renval
    Renz
    SoCal
    which shocks u recommend, not to expensive offcourse:)
  8. Mar 26, 2009 at 12:53 PM
    gdctaco
    gdctaco Well-Known Member
    georgetown, ont
    06 access cab 4x4 O/R
    rr diff mod in-cab 110
    bilstein 5100, seem to be the most popular and will cost around 200 for the front pair close to 400 all around, check the vendor section and hook up with downsouth motorsports, we get discounts!!
  9. Mar 26, 2009 at 12:58 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you are getting OME springs- Get the OME shocks. They are made to go together.
    Billies are also a good option...The choice between the two should be based on what you want to do with the truck...
  10. Mar 26, 2009 at 12:58 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    this is what i told another member, and chris corrected me :rolleyes:
    according to chris, these springs will ride the same (they have the same spring rate), the 885's are just a bit taller and will sag to give you about 3" of lift.
  11. Mar 26, 2009 at 5:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    the 885's will give a double cab 3" lift. Not sure what it would give an access cab. 884's are recomended for the access cabs, but many go with the 885's for the extra lift.
  12. Mar 26, 2009 at 10:28 PM
    renval
    Renz
    SoCal
    thank u guys.
