HELP: 96 Tacoma Differential Fluid Change - Engine Shaking and Check Engine Light
Discussion in '1st Gen. Tacomas (1995-2004)' started by ausbran, Apr 27, 2018.
  1. Apr 27, 2018 at 8:49 AM
    ausbran
    ausbran [OP] Well-Known Member
    Austin
    1996 Blue Tacoma Xtracab 4WD 2.7L
    I just changed my differential fluid on my front and rear differentials. I also did the transfer case. I replaced all fluids with Amsoil Synthetic Severe Gear 75w-90.
    I have a 96 Tacoma 2.7 4 cylinder 4WD.
    I drove about 10 miles right after the change and it drove great. Shifted smooth.
    Then I turned the truck off for about 30 minutes. When I came back and tried to drive the truck again, I put it in reverse and it started to shake a little bit, backed out of my drive way and it sputtered. Then I drove forward down the road a couple hundred feet and it continued sputtering slightly. Then the check engine light came on, so I drove back home and turned off the engine.
    What could have happened? I’m nearly positive I put the right amount in each component and I replaced all of the crush washers. Could this coincidentally be something else happening right after the oil change?
    I’m not going to drive the truck. Just going to get it towed to my mechanic and have him take a look.
  2. Apr 27, 2018 at 8:53 AM
    tony2018
    tony2018 Well-Known Member
    What is the check engine light for?
    TacomaJunkie8691 likes this.
  3. Apr 27, 2018 at 9:01 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Just changing the diff oil shouldn't affect the engine. Hmm
  4. Apr 27, 2018 at 9:01 AM
    ausbran
    Austin
    I don’t have a check engine light reader unfortunately.
  5. Apr 27, 2018 at 9:03 AM
    ausbran
    Austin
    Same thought I had. Really not sure.
  6. Apr 27, 2018 at 9:08 AM
    tony2018
    This is a 96...so there should be a way to read the cel by jumping pins? Might wanna look that up if you wanna get the ball rolling on this.
  7. Apr 27, 2018 at 11:21 AM
    ausbran
    Austin
    Any clue if this is an ODB2 port? It’s the port that’s in the engine compartment (has a small black cap that says diagnostics) as opposed to under the dash.
  8. Apr 27, 2018 at 12:06 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    Obd2 should be located under the dash right of the steering column
  9. Apr 27, 2018 at 4:33 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    You can buy an OBD II reader for 20 bucks or less..i got a decent one (pairs via bluetooth to phone) about a year ago and its been handy.
  10. Apr 29, 2018 at 7:17 AM
    ausbran
    Austin
    Unfortunately I live in Jackson, Wyoming where the cheapest one at Napa is $70. I borrowed one from a friend and figured out that cylinder 2 was misfiring.
    Replaced the spark plugs and wires and its back to running perfectly.
    Pervy and Taco302[QUOTED] like this.
