HELP!! 97 Taco 10A Gauge Fuse Blowing!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kyle0816, Jun 6, 2023.
  1. Jun 6, 2023 at 8:36 AM
    Kyle0816
    Kyle0816 [OP] New Member
    Kyle
    97 Tacoma extended cab
    Currently running the 97 Taco, the problem first started a few weeks ago. I hit a bump, this caused my 10A Gauge to blow. Any suggestions on how to fix this.
  2. Jun 6, 2023 at 8:38 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    loose ground or power at fusebox or in gauge. Could be shorting out somewhere else in the wire.
    Wulf likes this.
  3. Jun 6, 2023 at 8:42 AM
    Kyle0816
    Kyle
    How would I go about checking for the loose ground since that seems to be the quick solution
  4. Jun 6, 2023 at 8:44 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    get the wire and check both ends. Sometimes wire breaks down in the jacketing and you won't be able to see if its broke.
    Kyle0816[OP] likes this.
  5. Jun 6, 2023 at 8:46 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Slowly start looking for the short. Does the fuse open now when a new fuse is installed?
    Is there any electrical devices not working ? After market goodies installed?
    The fuse is loose in the socket you hit the bounce and caused it to arc any loose connections may also arc.
    The 10 amp gauge fuse protects many circuits.
    good luck.
  6. Jun 6, 2023 at 11:51 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It’s a 25 YO vehicle. Wire can be abraded anywhere. Fixtures can be cracked. Unless you get lucky and guess correctly, tracing wire is the eventual solution.
  7. Jun 6, 2023 at 7:02 PM
    Bivouac
    the 10 amp gauge fuse.
    Which protects many circuits.
    Taco critter likes this.
