Help! '98 Manual Trans Shifting Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by TuffTruck, Feb 11, 2011.
  1. Feb 11, 2011 at 1:21 PM
    TuffTruck
    TuffTruck [OP] Member
    Virginia
    98 Tacoma 4x4 3.4L, 3" lift & 31's
    3in lift, 31x10.5 BFG AT, K&N Cold Air, Flowmaster Exhaust
    So I bought my '98 4x4 SR5 V6 5spd Tacoma last weekend and I have had nothing but shifting problems since!
    Here is my post in the Won't Shift When Cold Thread. I thought I had it taken care of.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/121754-cold-wont-shift-2.html
    1st I thought the transmission fluid was just dirty and/or the incorrect fluid.
    =Changed it to Redline MT90
    2nd I thought it was the clutch master cylinder brake fluid which was almost black.
    =Changed it at the same time as the trans fluid. Flushed it from reservoir to the bleeder screw down on the "clutch release cylinder" (Haynes manual calls it) -aka- Slave Cylinder *that mounts on the drivers side of the transmission, and topped it off with new DOT3 brake fluid after bleeding the system.
    ***The next day on the test drive it shifted into every gear perfectly!
    ***The next morning after temps in the 20's it wouldn't go into gear until the engine was hot.
    3rd I thought, based on what I had read here that it was shifting very rough because of the cold temps.
    =I warm up the truck for 5 to 10 minutes! Getting it hot & at operating temp.
    ***This worked up until the 2nd day.
    I am pissed! What needs to be replaced or done so I can have smooth normal shifting. When I test drove it the truck had just been driven on the highway for 4 hours. When I shifted it didn't have a trace of tough shifting. Now I can't even muscle it into gear, or it grinds BAD if I do, OR sometimes if the RPM's are around 3k it will let you shift (as long as the engine is hot). The clutch pedal is not stiff and has good pedal with a couple inches of travel.
  2. Feb 11, 2011 at 4:20 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    How many miles are on the truck? If its old enough to have almost black fluids in the clutch the original owner probably didn't take care of the truck very well, maybe its time for a new clutch?
  3. Feb 11, 2011 at 4:24 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    sub'd. having a similar problem,only with 2nd gear though. recently changed the clutch fluid and also changed the tranny fluid from royal purple to amsoil manual transmission and transaxle gearlube 75-90 GL4. helped but not enough,i may try amsoils severe gear fluid to see if that helps that is if i can find some.
  4. Feb 11, 2011 at 5:23 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Try double clutching for 2nd gear and see if that helps, its possible you might have a bad synchro
  5. Feb 13, 2011 at 12:03 AM
    TuffTruck
    Virginia
    Ok I figured it out. Today I replaced the Clutch Master Cylinder and the Clutch Release Cylinder aka the Slave Cylinder.
    My initial test drive was perfect. 5 hours later and 35deg my next test drive was good also. The clutch disengages very positively.
    About 3 hours later and 35 deg I drove it again and it was good to go! I think these two parts were the issue all along but I am glad I put the Redline synthetic fluid in the trans and transfer cases. Everything feels really smooth.
  6. Feb 13, 2011 at 3:25 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    You probably had bad internal seal on one or both letting the clutch fluid past the piston not creating enough pressure to disengage your clutch..
  7. Feb 14, 2011 at 4:47 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    right on i may try this route. how much is it for the clutch master cylinder and the slave cylinder? id like to try some redline but theres not a place in town that sells it or has even heard of it,ebay it is i guess.
  8. Feb 15, 2011 at 12:29 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Autozone had the master for 50 and the slave was 30 or 40 I don't remember
  9. Feb 15, 2011 at 10:39 AM
    TuffTruck
    Virginia
    Correct on Autozone for the Master Cylinder because of lifetime warranty and Toyota wants about $140-$240 for it and it has to be ordered.
    The Slave you should get from Toyota its only $60. These last 100k at least! Spend the extra.
  10. Feb 15, 2011 at 4:23 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    ^^^ right on,ill be replacing them soon then
  11. Feb 22, 2011 at 4:26 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    picked myself up a new clutch slave cylinder(34$) and master cylinder(90$),im going to be putting them in on saturday. what was the install like OP? anything i should know?
  12. Feb 22, 2011 at 4:35 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Synconizers hope I spelled that right or a bad clutch.
  13. Feb 23, 2011 at 4:59 AM
    TuffTruck
    Virginia
    These parts fixed my described problem at the top. My truck combined with the Redline MT90 made my truck shift like a dream.
    But what you need to know is, get a big bottle of Dot3 brake fluid and bleed bleed bleed that clutch hydraulic system.
    And do not forget to put the clutch pedal return spring back on! If you do you will end up thinking you have soft pedal after the truck sits overnight or gets real cold while sitting. Happened to me.
  14. Feb 27, 2011 at 8:02 AM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    replaced them yesterday OP, the hardest parts was gettin the cotter pin back through the clevis that holds the master cylinders pushrod to the pedal, and also getting the line off the slave i ended up removing the wheel and reaching up over the frame.anyway got er all done and shifting is now much smoother:D.
  15. Feb 27, 2011 at 8:23 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Yeah just got my new slave cause my old slave is worn out and beaten too much.. I gota good price for it too lol I need to bust out the whip and break the new slave in soon
  16. May 19, 2013 at 1:03 PM
    Madjik_Man
    Colorado Front Range
    Old bump (hopeful for response)
    Did that clevis just pull through the firewall? Or did you have to remove it?
    I can't get it through the hole in the firewall.
