Help a College Student Buy a Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HelptheCollegeStudent, Mar 26, 2020.
  1. Mar 26, 2020 at 10:09 AM
    HelptheCollegeStudent [OP] Member
    Hi,
    I am a college student, and I am looking to buy a used Tacoma. My main priority is reliability, which led me to Tacos. I had three major questions about what to look for when buying. For context, I am trying to spend under $12,500 for the truck.
    1. I know frame rot is a problem, but I was wondering to what degree. I will be looking under the truck at the frame for all trucks, but I was unsure how much rust is too much. Is a little bit of surface rust here and there okay, or is that a sign that inside the frame is much worse? Should I only look for trucks with replaced frames or frames that look new (I say this because I will probably be buying a 2004-2008 given my budget)? Any guidance on how much rust is too much would be super helpful.
    2. Is there any threshold on mileage I should be looking at? I know Tacomas are in a different league when it comes to how many miles they can go (our family F150 died after 150k), but is there a certain point I should stay away? Maybe 150k or 200k? Or is it better to just look at service records in relation to miles, and not care so much about a specific number.
    3. Are there any major red flags that are specific to Tacomas that I should be aware of? I know general rules about buying used cars, but I was wondering if there was something to look for other than frame rot.
    This is my first time buying a car on my own, so any help would be appreciated! Thanks so much and stay safe
  2. Mar 26, 2020 at 10:12 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Sadly with how our trucks hold value, you’d be hard pressed to find a Tacoma with no previous/hidden problems for that price range
  3. Mar 26, 2020 at 10:12 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The second Gen trucks gave less issues with frame rot.
    If you look for 2010 or newer, it should be no issue.
    150k miles is not lots of miles.
    A newer truck with higher miles would be a better way to go, as that truck would have spent most of the time on the highway.
    TXpro4X4 and Sterling_vH111 like this.
  4. Mar 26, 2020 at 10:12 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    It's all a mind game :cool:
    TXpro4X4, six5crèéd and Hobbs like this.
  5. Mar 26, 2020 at 10:15 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Good questions and you already have a good base of what to look for.
    I’d follow the above statements about miles vs year, and your budget.
    I’ll also add that depending on where you are looking, France rust may not be too much of an issue.
    Ie. I’m in SoCal, so it’s almost not a problem in my area if I was looking for a truck.
    But if you live anywhere where they salt the roads, I’d make that aspect your first priority.
  6. Mar 26, 2020 at 10:19 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would take someone with you that’s knowledgeable around vehicles if you can or at least someone that has a little street smarts. You can also search out a shop beforehand and talk to them about your search and if you can bring a vehicle to them for an inspection.
  7. Mar 26, 2020 at 10:21 AM
    tcjacado
    tcjacado Well-Known Member
    Go install your wheels:boink:
    TXpro4X4, CrippledHo and Hobbs like this.
  8. Mar 26, 2020 at 10:23 AM
    Didn't think of it that way, but that makes a lot of sense. Thanks for that info. because I was definitely looking at less miles and older.
  9. Mar 26, 2020 at 10:23 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I'd look 2007 and newer to your price limit. 150K and under. Stock. Keep some of the money for after purchase expenses.
  10. Mar 26, 2020 at 10:24 AM
    Unfortunately, I live in the northeast so I gotta watch for it, although I could probably drive south to pick one up. Thanks for the help!
  11. Mar 26, 2020 at 10:24 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    And go easy on the lug studs.....
    TXpro4X4 and tcjacado[QUOTED] like this.
  12. Mar 26, 2020 at 10:25 AM
    koditten
    Kirk
    Central Michigan
    Definatly look for a stock truck! People who have installed lifts on their trucks did not gain reliability by doing the lift.
    tcjacado likes this.
  13. Mar 26, 2020 at 10:26 AM
    Yea the 12,500 is with another 2,500 ish for after purchase costs. I plan on building out my own camper once I have it slowly overtime. Thanks for the help
  14. Mar 26, 2020 at 10:29 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    My suggestions:
    1. Find a reputable mechanic/shop and get an thorough inspection before you buy.
    2. Previous maintenance and use determines condition. Try to buy one that has a maintenance history that you can verify.
    3. Don't be afraid to buy a truck that has been in a minor accident and been properly repaired. You get a discount (or you should be able to negotiate one).
    4. Stay away from salvage or flood vehicles regardless of price.
    maverick4x2 likes this.
  15. Mar 26, 2020 at 10:56 AM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    That's tomorrow
    tcjacado[QUOTED] likes this.
  16. Mar 26, 2020 at 10:57 AM
    tcjacado
    :annoyed::facepalm::frusty:
  17. Mar 26, 2020 at 11:09 AM
    My Name is Rahl
    You would know. You're the one playing mi d games with Priscilla.
    Hobbs and NYCTaco52[QUOTED] like this.
  18. Mar 26, 2020 at 11:39 AM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    You saw her, you'd play mind games with her too :anonymous:
  19. Mar 26, 2020 at 11:57 AM
    TexasWhiteIce
    Texas
    So how does one purchase a vehicle in times of social distancing from a private owner?
    TXpro4X4 likes this.
  20. Mar 26, 2020 at 12:48 PM
    spitdog
    Hey, just throw me your keys for a test drive and I’ll be right back. Wait a second, let me get my gloves on first dammit.
