help a lady out!
Discussion in 'Lighting' started by jeanna, Aug 22, 2010.
  1. Aug 22, 2010 at 9:40 AM
    jeanna
    jeanna [OP] Member
    seattle
    1995 toyota tacoma
    I have a canopy on the back of my truck and the overhead light went out. I tried replacing the bulb but it didn't work. I am sure it has to do with the wireing. Does anyone have any advice on how to fix or figure this out.
  2. Aug 22, 2010 at 9:43 AM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Look and make sure all the connections are good, if you have a voltmeter you can use that to see if your getting any juice to the canopy
  3. Aug 22, 2010 at 9:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Also check the fuse
  4. Aug 22, 2010 at 9:52 AM
    jeanna
    jeanna [OP] Member
    seattle
    1995 toyota tacoma
    thanks
  5. Aug 22, 2010 at 9:54 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2...where's the power coming from for this light?
