HELP AC Expansion Valve 2008 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chivo140, Jun 2, 2016.
  1. Jun 29, 2016 at 4:07 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Doubful. I was dreading an evap change when I redid my system but it's been working fine. Only thing I did was flush the evaporator. It's not perfect by far given the construction of it, but I wanted to get all the old oil and dye out.
  2. Jun 29, 2016 at 4:09 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    If you take the glove box out, you can see the black box referenced in JimmyH's post with the cutaway.
  3. Jun 29, 2016 at 4:14 PM
    Syvman
    Syvman Well-Known Member
    Terry
    Mesa, Arizona
    2009 Red SR5 4x4 DCSB
    Thanks - that is encouraging that you haven't had issues after sticking with the old one.
    I'll take a look and see if it's feasible to try one of those cleaning sprays.
  4. Jun 29, 2016 at 4:31 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Worse thing that can happen is it doesn't work, right?
    My 05 never had a cabin filter in it either.
  5. Nov 20, 2020 at 4:34 AM
    SilverStreakTaco2
    SilverStreakTaco2 Member
    2008 Tacoma 4x4 2.7l, 5-speed manual
    Hey guys (and gals), I’m about to attempt to replace my expansion valve but it’s not an ordinary bolt. I’m wondering what size/kind of Torx tool I need to remove it??
  6. Nov 20, 2020 at 5:26 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    expansion valve is pretty easy as shown from the engine bay.
    SilverStreakTaco2 likes this.
  7. Nov 20, 2020 at 8:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Torx Socket E10 and then the two mounting bolts are Torx T25.
    https://www.tacomaworld.com/threads/a-c-filter-screen.482864/#post-24272716
    Don't forget the filter mounted inside the refrigerant line.
  8. Nov 21, 2020 at 1:42 PM
    Taco'09
    Taco'09 Well-Known Member
    Oh, for you guys doing this make sure you replace the seals on both sides of the expansion valve with OEM. Beware that Toyota used a different part number for one of the seals on the engine side of the valve than the evaporator side so plan accordingly that this little surprise will not ruin your day. The seals are these:
    Engine Side of Valve
    - Upper 90210-A0001
    - Lower 90210-A0002
    Evaporator Side of Valve
    - Upper 90210-A0004
    - Lower 90210-A0002
