Help. Ac problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tjs, Jan 4, 2020.
  1. Jan 4, 2020 at 5:58 PM
    Tjs
    Tjs [OP] Active Member
    2005 TRD Offroad
    Hi. I recently changed my compressor and did over the system. Thing is. I noticed as of today that when i turn on my ac the rpm drops by 100 or little over and the compressor does not disengage as it should. It just keeps running until i manually turn it off. But it is blowing cold air and even colder when i drive. Now my question is. What is the problem for it to not disengage and also for it to drop the rpm????
  2. Jan 5, 2020 at 2:40 AM
    Ricky o7
    Ricky o7 New Member
    Richard
    07 tacoma
    May have a relay stuck or shorted or you over charged system also check pressure switch since you mentioned the 100 RPM drop I'm leaning towards overcharged
    Muddinfun likes this.
  3. Jan 5, 2020 at 5:52 AM
    Tjs
    2005 TRD Offroad
    Oh okay bro. Thanks for the reply. I will have it checked right away and give feed back.
