Help - AC, Speedo, Windows all don't work and CEL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1E7DCSB, Jun 22, 2018.
  1. Jun 24, 2018 at 11:04 AM
    Muddinfun
    Muddinfun Well-Known Member
    That sounds bad. If you continue to drive it, it could cause more damage. Call the shop. Tell them it's knocking. Do they want you to drive it, or do they want to pay for a tow.
  2. Jun 24, 2018 at 11:04 AM
    Clearwater Bill
    Billy
    Largo Florida
    Well I'd see that as good. 'Cause you can check on them along the way....
    1E7DCSB[QUOTED][OP] likes this.
  3. Jun 24, 2018 at 12:01 PM
    1E7DCSB
    1E7DCSB [OP] Well-Known Member
    NH
    I think the clutch is rubbing the pulley or the field coil behind the pulley is touching the pulley. No need for a tow, IMO. Worst case it gets a new oem compressor but we will see
  4. Jun 24, 2018 at 2:29 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    My guess, the ring clip on the stator popped off, the short was from the wires on the stator being pulled or rubbing on the pully, the noise is loose stator. Look behind the pully at the red and black wires.
  5. Jun 24, 2018 at 2:32 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    If the clutch was rubbing on the pully, when dissengaged the clutch would still turn. Run it for a few minutes, shut it off. Touch the front of the compressor. If the clutch isn't disengaging it will be HOT!!!!
  6. Jun 24, 2018 at 2:36 PM
    Tacoma Mike
    Southern Maine
    This #1 to check..
  7. Jun 25, 2018 at 7:58 AM
    1E7DCSB
    NH
    Clip popped off as predicted. Truck has been running for half an hour in the shop and so far so good
    Skyway likes this.
  8. Jun 25, 2018 at 4:34 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Good to hear that you got it figured out, to be on the safe side, I'd get a flashlight and check the wires just to make sure they are not damaged. Could cause a short later, or even a small cut in the insulation could cause enough of a minimal short to drain the battery, but not enough to blow a fuse. 5 mins of your time could save you a headache later :)
  9. Jun 25, 2018 at 5:03 PM
    1E7DCSB
    NH
    Thanks for the help! I’ll take a look at it tomorrow afternoon if I get a chance after work. Not driving the truck until the weekend
  10. Nov 3, 2021 at 6:45 PM
    Azulsegovia
    Azulsegovia New Member
    07 Tacoma
    Hi have same issue now. I noticed windows, AC not working; abs, brake and traction control lights on. Couple mins later, tire pressure light and check engine lights turned (my dash looks like a christmas tree). Took it to autozone and the tool indicates abs wheel speed sensor only. Prior to today, a couple days ago, I replaced ignition switch. Problem was solved immediately….unfortunately, problem came back today. Prior to today, I had no check engine light.
  11. Nov 3, 2021 at 7:16 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked all the fuses for power on both sides? IG1, IG1 No2, IGN, or ECU-B fuses would be suspect as they feed all those systems, also check the short pin in the underhood fuse box as they had a problem with sometimes losing connection.
    Could also be a defective ignition switch with the shitty quality of parts these days.
    ardrummer292 likes this.
  12. Nov 3, 2021 at 7:31 PM
    Azulsegovia
    07 Tacoma
    Will try tomorrow morning. Thanks for the advice.
  13. Nov 4, 2021 at 3:03 PM
    Azulsegovia
    07 Tacoma
    Hi. I checked the fuses and there was one, half way out!!! I pushed it in and the lights turned off!! All power is back to normal. I have no idea how this fuse ended up like that. thanks fo the tip.
    Steves104x4, ardrummer292 and Dm93 like this.
  14. Feb 15, 2023 at 3:42 PM
    Darian1011
    Darian1011 New Member
    Darian
    2000 Toyota Tacoma SR5
    Having the same issues.. no thermostat, RPM, or speedometer gages. Windows also won't roll down, heater & AC don't work. Did they ever diagnose your issue?? I checked the fuse box & the #9 fuse was halfway pushed out still good. Replaced it & still having issues.
  15. Feb 15, 2023 at 3:50 PM
    #35
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you checked all the fuses for power on both sides? IG1, IG1 No2, IGN, or ECU-B fuses would be suspect, also check the short pin in the underhood fuse box as they had a problem with sometimes losing connection.
  16. Oct 10, 2023 at 3:31 PM
    #36
    Bbelk6805
    Bbelk6805 New Member
