HELP! Added lift and now traction control is on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Armyhater458, Apr 6, 2018.
  1. Apr 7, 2018 at 1:04 PM
    Armyhater458
    Armyhater458 [OP] Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    I don’t know for sure. They are stock Baja wheels.
    I think they are -12 offset, 4.5 bs, 7.5 wide, 16 radius
    I could be wrong about the offset it may be zero. I below the above numbers to be correct though.
  2. Apr 7, 2018 at 1:06 PM
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Sounds like a helicopter task lol
    Bebop[QUOTED] likes this.
  3. Apr 7, 2018 at 1:10 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Yeah I know it does.
  4. Apr 7, 2018 at 1:30 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    I had similar issue but with17x9 -12mm offset with 265/70’s.
    I pulled the very front mini flaps off completely. The inside edge of the front tires would rub during certain turns on rearmost flaps on the front. Mostly when i was half lock and hit a bump during a turn. This was mostly because of the negative offset. You are probably getting because your tires are taller.
    I removed the flaps and cut out a portion of the plastic flare. I then reinstalled the flaps used a head gun and a 2x4 and to mold them in further, ended up working out.
  5. Apr 7, 2018 at 8:05 PM
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    As said in previous posts yaw rate sensor probably needs calibration. Nose-up condition indicates a “skid” on our trucks apparently. Does your VSC system kick on when you take turns? The trac light should flash and your truck should beep at you. I had the same issue after my lift which is almost identical to yours. I just said screw it and never calibrated, seems like the truck has recalibrated itself over the course of about 25k miles
  6. Apr 8, 2018 at 3:23 PM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    I haven’t had the VSC actually kick in yet, but I can’t cycle through the settings either. If I hit my button it doesn’t do anything and should turn a couple options off. I’ve tried holding for 5 secs to disengage all VSC but the light remains solid at all times. The ABS auto engage hasn’t happened yet. I don’t want it to, and want the damn light off though. I’m going to try to delete and recalibrate like a link in this thread suggests. I still have a little rake , pretty close to factory.
  7. Apr 9, 2018 at 5:38 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    I am going to get a switch today to build a little jumper to do the manual reset. Lets hope that works. I ended up taking off my front mudflaps for now. I would like to get a heat gun, and attempt a little modification to them before going a separate route. Has anyone had any luck with aftermarket mudflaps and 255/85/16? I also seem to rub a little when stuffing the tire on a turn. It isn't too bad, but I would like to figure all this out. I though going the full 3" would prevent all of this. If it wasn't for bad luck I wouldn't have any at all. I guess I should be happy that it aligned, and no vibes so far.
  8. Apr 9, 2018 at 6:24 AM
    Pigpen
    Dan
    Northwest Montana
    I have these on front and rear
    https://www.amazon.com/dp/B0002NIJS0
    As far as rubbing goes, a 3" lift should stuff just as far as stock suspension. You need to adjust your caster to prevent rub. After that, it's all :sawzall::welder:
    With 255/85/16s on stock steel wheels, I don't rub anywhere and I haven't trimmed anything. Before putting in UCAs, I rubbed the back of the wheel well when stuffed and turned. Also, before adding spacers to my top plates for additional lift (with 885 coils) I had rubbed the top of my wheel well a couple times at full compression.
  9. Apr 9, 2018 at 7:34 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    I am attaching my alignment numbers. They told me you guys didn't know what you were talking about and i didn't need 3 degrees of caster. I am wondering if that would make the difference. Also it appears that my wheel is more towards the rear of the fender than the front. What adjustment can be made to correct that? LCA or UCA? Or is it just that the axle is there and that is where it mounts? Sorry pretty ignorant when it comes to the mechanical side of things.
    Thanks for the link to mudflaps, I'll definitely check into those.
  10. Apr 9, 2018 at 7:37 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    You should be good with the 255s. I just went to the skinny tire and have only noticed rub at about 1/4 turn while going up hill. All flaps have been removed for awhile now and I don't like the look of them.
  11. Apr 9, 2018 at 7:41 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    With the front flaps removed I did get rid of most of the rubbing. I still have some very minor rubbing when stuffing. I haven't been able to identify where though. I am taking it in the re-torque everything after running it for a weekend. I will have a better look while it is up on the lift. My rub is also about 1/4-1/2 turn. Straight and full lock do not rub at all.
  12. Apr 9, 2018 at 7:48 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    FWIW I have the same lift and had 0lights before and after. So I'm not sure the vsc light is that common after lifting.
  13. Apr 9, 2018 at 7:54 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    I didn't have the light until the alignment was done. That is what doesn't make sense to me, but the link in the beginning of this thread makes me feel a little more at ease. i just have to make the jumper with switch to try the fix.
  14. Apr 9, 2018 at 6:22 PM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    I took the truck into the shop that installed the lift. They used their OBD2 reader and reset the VSC.
    Pigpen likes this.
  15. Apr 9, 2018 at 7:56 PM
    #35
    Pigpen
    Dan
    Northwest Montana
    Truck should drive pretty nice with those numbers. If you want more caster, get SPC UCAs. You'll also get more down travel from them because of the extended ball joint and wider inboard opening (won't hit your coils like stock UCAs). They're lower profile too, so your tires won't rub them.
  16. Apr 10, 2018 at 4:04 AM
    #36
    Armyhater458
    Clarion, PA
    2012 TX Pro
    I’ve got SPC UCA. That is why I’m wondering if I should push the issue with caster and try to get it to 3 degrees.
  17. Apr 10, 2018 at 3:37 PM
    #37
    Pigpen
    Dan
    Northwest Montana
    I'm running at 2.5 caster without issues. If I was going to get an alignment, I'd bump up to 3. It drives fine though, so I'm not changing it at the moment.
  18. Apr 10, 2018 at 3:53 PM
    #38
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP is your steering wheel centered?
  19. Apr 10, 2018 at 6:05 PM
    #39
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Steering wheel is centered and drives great down the road. No pulling and steering feels tight. I haven’t had it on the highway yet, but doesn’t seem to wonder going down the road so far.
  20. Apr 11, 2018 at 7:33 AM
    #40
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Can anyone explain castor in a way I can understand. More specifically why 2.5-3 is ideal with 3" of lift. Why 3 is preferred over 2.5? If I should push my numbers to 3 degrees?
    As far as I am concerned with my numbers it seems to drive alright and tracks pretty straight. I don't see a need to change the set-up, but if there are benefits I would definitely consider it. Thanks for the enlightenment!
