Help adjusting Bilstein 5100s
Discussion in 'Suspension' started by 09Doright8126, Nov 2, 2009.
  1. Nov 2, 2009 at 7:04 AM
    09Doright8126
    09Doright8126 [OP] Well-Known Member
    Andrew
    Greenwood, SC
    '09 DC TRD Offroad Pyrite Prerunner
    Aires chrome bullbar, Wet Okole seat covers, 6" KC offroad Slimlites w/ covers, upper Grillecraft black w/ TRD emblem, Redline hood struts, URD TCAI w/ black wrap, URD MAF Sensor, NST pulleys, NST intake manifold spacer, Bilstein 5100s, Eibach coils painted red, painted red brake calipers, SST brake lines, debadged tailgate, window tint, bed mat, extra D-rings, Rear TSB, Tranny TSB, swaybar removed, DTLT headers, URD Y-pipe, Vibrant Resonator, MagnaFlow
    Does anyone know how to move the circlip on these shocks?! I've received mine on the 1.75" setting and need to get them adjusted to the stock setting....
    Any help would be much appreciated as this is the only thing holding up my installation.
  2. Nov 2, 2009 at 7:16 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    you need some circlip pliers i'm pretty sure....... i didnt have any problems with mine.......... or if it's the other hind of circlip (just a round wire) slip a small fine flat head in there and pop it out
  3. Nov 2, 2009 at 7:17 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    I think I just grabbed mine with some needle nose and slid one side of the clip down at a time. I think they are pretty tough, don't think you will break one.
  4. Nov 2, 2009 at 7:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be able to pull the C clip out with your fingers. It just slides/pops off.
  5. Nov 2, 2009 at 10:12 AM
    09Doright8126
    Andrew
    Greenwood, SC
    Ok, thanks guys... I will try first thing when I get home. After installed sometime this week I will post some pics.
  6. Nov 3, 2009 at 5:37 AM
    09Doright8126
    Andrew
    Greenwood, SC
    Was able to move the circlips by using needle nose pliers to open up the clips then sliding them down to the appropriate setting.
