help adjusting toytec coilever
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Newtaco2012, Jul 7, 2013.
  1. Jul 7, 2013 at 6:52 PM
    Newtaco2012
    Newtaco2012 [OP] Well-Known Member
    Jeremy
    Corpus Christi
    2012 tacoma sport
    toytec adujstable coilover
    can somebody help or explain how to adujust the ride height of the adjustable coilover toytec its set pretty low i have the tool to do it but dont know how?
  2. Jul 8, 2013 at 1:38 PM
    Dano.oh
    Dano.oh Member
    Dan
    Denver
    2013 TRD OR DC 6 spd.
    3" Toytec Ultimate lift, Light Racing UCAs.
    I adjusted mine with the suspension unloaded and on the truck. If I remember correctly the directions tell you they are adjusted from the factory to give you a slight rake so if you want your Taco level, you have to adjust em. Also, I think the directions tell you to use a breaker bar to get the leverage and just spin em. It takes a good bit of pressure to get them to move, but once you get the first turn its not too bad. Get yourself a good sized buddy to hold the second wrench and you should be good to go. :thumbsup:
