Help aiming HID offroad lights
Discussion in 'Lighting' started by bluewaters182, Jul 17, 2014.
  1. Jul 17, 2014 at 8:32 PM
    bluewaters182
    bluewaters182 [OP] Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    So I searched and couldnt find anything. I know a lot of folks are running Kragen HIDs and so I figured for the price I'd try them. They are bright, my issue is the up and down adjustment is in too large of increments. They are either aimed short on the road or up in the trees. There is no in between. FYI they are mounted upside down on the light hoop of my bumper. With so many others running these I can't imagine I'm the only one who has run in to this. Anyone have any ideas on a solution. Thanks
  2. Jul 17, 2014 at 8:35 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Adjust some with washers
  3. Jul 17, 2014 at 8:51 PM
    bluewaters182
    Greg
    Ohio
    I was thinking some kind of a shim. Is that what you mean with using a washer? Because I wouldn't think putting a washer in there would change the angle just the height, but the difference in one click up is really a high angle, I would think with flat washers they would still be angled up, just lower on the mounts?
  4. Jul 18, 2014 at 12:00 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I used body washers between my bar and the bottom mounting bracket to raise them up, and then set the angle from there with the notches.....
    each vehicle is different tho, and I was using fogs, so
    A: u want a ton of spread plus
    B: without a projector, aiming HIDS is not perfect.
  5. Jul 18, 2014 at 10:08 AM
    bluewaters182
    Greg
    Ohio
    Thanks I will see what I can come up with.
