Help an electrically challenged person out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TxStVanWilder, Sep 7, 2020.
  1. Sep 7, 2020 at 7:26 AM
    TxStVanWilder
    TxStVanWilder [OP] The Pale Horse
    Tx
    2013 TRD Sport
    posted this in lighting as well, but there might be more traffic in this section vs there some days...
    2013 DCLB Sport model
    Ok so ill give you some background on my issues as they've come. Im sure its something simple, but I cant find my Haynes manual to read through and figured the more knowledgeable folks here are more helpful anyways
    A few months back i purchased a set up used VLED switchbacks from a member here. Thanks to USPS the arrived broken and the glass lens on the front of was broken loose. I contacted VLEDs and their customer service was phenomenal and told me how to epoxy the broken piece back on. So I did that. At that time I also ordered the double sided mounting tape for the pieces that need to be secured.
    So a week later they come in, I install the VLED's and one doesnt work. i switch things around to double check if its a bulb or driver issue (i know its not called a driver i think thats only on HIDs, but no clue what to call it). Its the bulb itself. At this point I get frustrated after mounting and getting everything going. So i leave the single good VLED and single bad VLED in their spots and just figure ill go back and buy new regular bulbs when i feel like getting around to it. Until then i just leave the DRL lights off.
    One evening I leave my truck running to grab something and I notice that the runnnig/amber light isnt on when i have the headlights on. That same drive i now realize my turn signals nor flashers do not work at all. Great. I replace the VLEDs and put regular bulbs back in and check the fuses and the turn signal fuse is bad. I replace it and all is right again in the world of turning
    Now here is where I come to the professionals for help. Since its starting to get a little darker earlier, i have noticed a few things. I dont know if these are even related or if im just imagining it all together... Are the radio controls and the HVAC controls back lit? If so i have no back lights on them.... ALLLLSOOOO last week i got a call from a friend as i was leaving the neighborhood telling me to turn my headlights on... They were on, but now it also turns out my rear running lights when the headlights are on do not illuminate... Is there a fuse or something i need to check there as well? I dont know if this is even related to the turn signal issue, but it sure seems convenient that it all happened around the same time
    TLDR: Installed LED's, popped that fuse. Could or did that mess up another fuse that could effect backlighting on radio and HVAC and now i have no rear running lights when headlights are on as well.. Any of this related or am i just an unlucky SOB with lighting issues
  2. Sep 7, 2020 at 7:31 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Check your fuses yes. You or the previous owner likely
    A) plugged in an LED unit without the driver module
    B) have the regular 3157 bulb adapter, not the 3157CK unit the front needs.
  3. Sep 7, 2020 at 7:47 AM
    TxStVanWilder
    Tx
    2013 TRD Sport
    I currently have regular OEM bulbs back in there with a new fuse...
    turn signals & flashers work as do brake lights.... But no running lights in rear
  4. Sep 7, 2020 at 7:49 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Did you check the fuses for the other circuits that are out?
  5. Sep 7, 2020 at 7:50 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Keep checking fuses. Check the running light bulbs in the back, maybe they both burned out coincidentally
  6. Sep 7, 2020 at 7:51 AM
    TxStVanWilder
    Tx
    2013 TRD Sport
    All I currently have is the small diagram under the fuse cover. I checked there this morning and didnt see anything that said running lights or something of the sorts... If someone has an opportunity to lead me in the direction of where it may be, i would be very grateful
  7. Sep 7, 2020 at 7:51 AM
    TxStVanWilder
    Tx
    2013 TRD Sport
    OEM LED tail light rears
  8. Sep 7, 2020 at 7:52 AM
    Too Stroked
    Tom
    Your Owner's Manual has a complete listing.
    BTW, Your rear running lights, license plate lights and dash illumination lights are all on the same circuit.
  9. Sep 7, 2020 at 7:54 AM
    TxStVanWilder
    Tx
    2013 TRD Sport
    Purchased truck used in 2015, no manual in the truck.... SO as you can see im extremely prepared when it comes to things like this :facepalm:
  10. Sep 7, 2020 at 8:00 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  11. Sep 7, 2020 at 8:09 AM
    TxStVanWilder
    Tx
    2013 TRD Sport
    FIXED IT!
    I’ve owned this truck 5 years and never once opened that little cubby next to my left knee, yet even known there were fuses back there.
    thank you! This is why forums are so much better than social media! The knowledge base here is far greater
    mtip and Too Stroked like this.
