Help! Annoying clicking!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ilovetacos, Nov 2, 2009.
  1. Nov 2, 2009 at 10:43 PM
    ilovetacos
    ilovetacos [OP] Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I have developed a very annoying clicking noise coming from my drivetrain/under the truck. At first I thought it was my front-right brake caliper but I pulled the wheels and put some grease on the pad clips but the click is still there. The CV's look fine and nothing is wrong with brakes.
    This evening I took it for a drive and also had a friend it drive by me so I could hear the click a little better. It seems like it clicks everytime the transmission shifts (up or down). The click is pretty loud and very noticeable.
    Any input would be appreciated. I don't want to take it to the dealer!
    BTW my Tacoma is an '06, automatic transmission, 4x4 and 49k miles.
    TIA!
  2. Nov 3, 2009 at 7:58 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    drive shaft maybe?
  3. Nov 3, 2009 at 8:52 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Had the drive shaft lubed today and clicking still there.
    Anybody else have an idea?
  4. Nov 3, 2009 at 9:12 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    just because it was lubed doesn't mean a U-joint isn't bad. If it happens everytime you shift, chances are its in the rear driveshaft or transmission. Since driveshafts are easier to work on I'd start there. Grab your drive shaft and try to rotate it back and forth. It should be very solid and if any movement, you should be moving your truck slightly. If you feel ANY play at all you've got a bad u-joint. Also check to make sure your carrier bearing is tight. I've had one work lose before on another vehicle.
  5. Nov 3, 2009 at 9:28 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Thanks, I'll check it out tomorrow.
  6. Nov 8, 2009 at 10:40 AM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    I finally got under the truck this morning. On the front driveshaft above the carrier bearing and before the transmission I can move the driveshaft about 1/4" each way. When I move it I also can hear a clicking noise very similar to the clicking I am hearing when driving but I also get the same clicking when I move the driveshaft between the trans case and transmission. So is it a bad u-joint? The clicking sounds like it's coming from the transmission. :confused:
