Help Annoying Creak Coming From The Front Suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhion82, Nov 17, 2015.
  1. Nov 17, 2015 at 4:19 PM
    rhion82
    rhion82 [OP] El Duderino
    Mitchell
    TN/GA
    16 Taco
    Over the past couple of weeks the truck has developed a creak/squeak that only occurs when I turn to the right. Where do you think the noise is coming from? I have tried to determine it for my self but I have come up short. I bought some dry lubricant from pep boys and sprayed down the bushing, ball joints, and the spindle to see if the noise went away but it failed..... Help me this noise is driving me crazy:crazy::crazy::crazy:
  2. Nov 17, 2015 at 5:26 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Sounds like one of the ball joints or the outer tie rod end has dried out. Don't bother to try to relube it once it get to that point it should be replaced. If you have someone steer the wheel for you you can CAREFULLY feel the area near each of these components. Usually when it makes that sound there will be a vibration in that area. JUST DONT PUT YOUR HAND WHERE IT CAN BE CRUSHED
  3. Nov 17, 2015 at 6:55 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    My bet is on the strut mount wearing against the shock piston rod.
