Help ASAP! Stuck in 4WD!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SteveB313, Jul 21, 2018.
  1. Jul 21, 2018 at 4:04 PM
    SteveB313
    SteveB313 [OP] Well-Known Member
    Detroit
    20 Tacoma TRD OR blackout/MGM, dbl-cab, AT3W’s
    Hey all, I’m in my ‘18 OR, middle of nowhere northern Michigan, 500 miles from home. Was on a muddy road so I successfully put it in 4L, even tried MTS mud & sand. Went fine. I wanted to move it 4L back to 4H, and into 2WD as I was about to enter a paved road again. It before I could exit MTS it made a terrible high-gear whirring noise with no drive. I came to an (already slow) stop. No drive from D whatsoever, so I put it in P, turned it off and on again, then it found itself apparently in 4H, yet with the 4WD indicator blinking nonstop. This has continued no matter what I do, P, R, N, D, off, on, any combo. Just stuck in blinky 4H! 9 more days of vacation driving Help!!!
  2. Jul 21, 2018 at 4:10 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Only thing I can think of is put it in N, back into 4L, then D and see if you can move. once you do that put it back into N, and switch to 4h and try moving.
  3. Jul 21, 2018 at 4:13 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Did you stop, put it in N and then switch from 4LO to 4HI or try to do it on the move?
  4. Jul 21, 2018 at 4:13 PM
    SteveB313
    Detroit
    It just stays in 4H while blinking, no matter if I select 4L or 2WD, neutral to D to anything, even shut off and on. Just 4H while blinking indefinitely.
  5. Jul 21, 2018 at 4:17 PM
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    Make sure you turned off CC and MTS?
  6. Jul 21, 2018 at 4:17 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    When you switch from 4LO to 4HI were you stopped? Did the 4LO light turn off? Try putting the switch in 4HI with the truck off, start the engine and drive forward and backwards while turning the wheel.
  7. Jul 21, 2018 at 4:19 PM
    SteveB313
    Detroit
    Yes, all are off, in fact trying to even go back into one says “go to 4L”, but my dash seems unaware that it’s actually stuck in 4H.
  8. Jul 21, 2018 at 4:23 PM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    Try going in reverse while making a turn.
    StayinStock and Sandman614 like this.
  9. Jul 21, 2018 at 4:24 PM
    SteveB313
    Detroit
    So I turned it off with knob in 4H, when turned on again it at least stopped blinking like it now knows it’s in 4H. I then try to properly move it into 2WD and it just blinks and stays in 4H.
  10. Jul 21, 2018 at 4:25 PM
    SteveB313
    Detroit
    Nope, just stays in. Wheel chirps and all.
  11. Jul 21, 2018 at 4:29 PM
    JoeCOVA
    Joe
    Colorado Springs
    Tow truck
  12. Jul 21, 2018 at 4:30 PM
    SteveB313
    Detroit
    I can get it into 4L, but then coming back to 4H while stopped in N I get that terrible gear buzz noise. Same thing if I shut it off/on again. I can shut it off in 4H, then when back on I try 2WD but it yet again just blinks and stays in 4H.
  13. Jul 21, 2018 at 4:32 PM
    DrSouthpaw
    DrSouthpaw Dog limo
    Spur
    AZ
    2017 MGM TRD OR 4x4 DCSB
    What if you disconnect the battery and let it sit for 5-10? Maybe the electronic mechanism will reset
    4drtaco03, danbow, Anchovy and 3 others like this.
  14. Jul 21, 2018 at 4:32 PM
    melikeymy beer
    2019 Tundra
    After you get it to 4H have you switched to 2WD and drove it for a distance to see if it will change?
  15. Jul 21, 2018 at 4:34 PM
    jeprox
    jeprox Well-Known Member
    Disconnect ur battery to reset to see if it works.
    CaptainBart45 likes this.
  16. Jul 21, 2018 at 4:36 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Try going back and forth from D to R with foot on the brake, a few times, then see if it goes to 2wd
  17. Jul 21, 2018 at 4:36 PM
    SteveB313
    Detroit
    Drove several miles, high speed to stop and go, stays in 4H the whole time.
  18. Jul 21, 2018 at 4:40 PM
    melikeymy beer
    2019 Tundra
    Could be a wet actuator. When driving through the mud was there standing water?
  19. Jul 21, 2018 at 4:43 PM
    SteveB313
    Detroit
    Negative. Actuator is actually clean. I’ve tried jabbing at it, can get it to pivot without any tools.
  20. Jul 21, 2018 at 4:43 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Warranty void because offroad truck is not actually meant for offroad.
    Capt Jrod, 270, jamonsote and 2 others like this.
