Help! ATF leaking, but from where?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Revelations, May 25, 2016.
  1. May 25, 2016 at 6:20 AM
    Revelations
    Revelations [OP] Well-Known Member
    2014 MGM DCSB
    I did a transmission flush this past weekend. No problems the last few days of commuting to work. Today, I get to the exit and I see smoke coming from the bottom of my truck. I get to work and crawl underneath. There's ATF all over the front part of the driveshaft. I can't figure out where it came from because the fill hole is on the opposite side. Is there an overfill/breather that the fluid came out from?
    I used an OBD tool to check the fluid temp. I checked it when it was 123F. It was down about a quart and a half, so I filled it until fluid came out. Then I shifted through all the gears. The fluid temp was still around 120.
    Crom likes this.
  2. May 25, 2016 at 7:30 AM
    Revelations
    2014 MGM DCSB
    I think it's coming from the Driveshaft seal. I'm dropping it off with the dealer today.
  3. May 25, 2016 at 7:34 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    If you did the transmission flush yourself, do you think the dealer will cover the leak?
  4. May 25, 2016 at 7:35 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    So you have a 4x2 Prerunner? How much rear lift are you running?
  5. May 25, 2016 at 7:37 AM
    KenLyns
    Belly of the Beast
    A tranny flush on a low-age vehicle should not cause external leaks. And OP doesn't have to tell the dealer about the flush.
    Revelations[OP] likes this.
  6. May 25, 2016 at 9:02 AM
    Revelations
    2014 MGM DCSB
    It's a 4x4. No lift.
  7. May 25, 2016 at 9:24 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    If you did a flush, where did you extract the fluid from? At the radiator?
  8. May 25, 2016 at 10:41 AM
    Revelations
    2014 MGM DCSB
    Yes, I turned the truck on and let it pump out a few quarts at time. Refilled in the fill hole.
  9. May 25, 2016 at 3:15 PM
    KenLyns
    Belly of the Beast
    How can the transmission be leaking from the driveshaft seal on a 4x4? On a 4x2 Prerunner, yes, but 4x4s have a transfer case between the transmission and the driveshafts.
  10. May 25, 2016 at 3:16 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I think you may have a leak at the hose connection where you flushed it.
    Why are you flushing the transmission on such a young truck?
  11. May 25, 2016 at 3:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I'm pretty sure he is talking about the propeller shaft seal.
  12. May 25, 2016 at 3:21 PM
    KenLyns
    Belly of the Beast
    That seal would be on the transfer case.
  13. May 25, 2016 at 6:57 PM
    Revelations
    2014 MGM DCSB
    There is a shaft that goes between the front differential and transfercase. That shaft got soaking wet with ATF. I chose to do the flush because it just turned 36k and I have been reading that the transmission may have come low on fluid. The past few months, the truck would shift way too soon and it was never a smooth shift.
  14. May 25, 2016 at 7:11 PM
    2015WhiteOR
    Gainesville TX
    If the front driveshaft was never covered in ATF before, then you need to retrace your steps from the flush. Unless you drove over something funky there is no reason why you'd see what you're seeing.
  15. May 25, 2016 at 8:14 PM
    Revelations
    2014 MGM DCSB
    It's already at the dealer. thanks.
  16. May 26, 2016 at 3:53 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    theres a breather on top of the trans. what probably happened is that you over filled it and when the it got hot the fluid expands and has to go somewhere and it went out the breather. i work at a dealer and seen it before.
    theres a certain way you have to drain and fill the fluid . and if your draining hot trans fluid it will be more then if it was cold and most people dont think of that so its common to over fill the trans.
    Lester Lugnut and TacomaMike37 like this.
  17. May 26, 2016 at 3:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    OK. I was just trying to clarify what he was saying...
  18. May 26, 2016 at 4:00 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I saw where you said your rig is at the dealer. I'm interested in your resolution.
    As far as I can remember there is a breather for the transmission. It's in the engine bay, and I believe it's almost dead center of the truck, behind the motor by the firewall.
    Lester Lugnut likes this.
  19. May 30, 2016 at 6:30 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Crom inquired about the outcome last week.
    What happened?
    Crom likes this.
  20. May 31, 2016 at 4:35 AM
    Revelations
    2014 MGM DCSB
    The transmission was over filled and fluid came out of the breather. There must be a problem with the calculation I used for the PID I used for the obd app. I'll use the pin jumper method next time.
    Crom likes this.
