HELP!!! bad bucking and jerking
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacocass, Apr 21, 2013.
  1. Apr 21, 2013 at 12:20 PM
    tacocass
    tacocass [OP] Active Member
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    BIL 5100'S, PRO-COMP 1" REAR BLOCK, DECK PLATE MOD W/ KN
    First, 02 Taco 4x4 3.4l: I was driving in second gear yesterday coming off a stop and went wot to pass someone. Next thing I know the check engine light is flashing at me, and the vehicle is violently bucking... Since yesterday, I have changed all 3 coils, plugs, wires, fuel filter, pcv, and maf... No change and all are oe componets. The vehicle starts and idles fine. It only misfires under load( climbing a hill or in first gear), or wot. It will only misfire after 2300rpm. Please help this is my dd... I am lost.
  2. Apr 21, 2013 at 12:21 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    oh ya and no stored or present codes...
  3. Apr 21, 2013 at 12:43 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    Has the timing belt been changed? Don't know if it is that, I'm just throwing it out there.
  4. Apr 21, 2013 at 12:46 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    don't think the timing belt would cause this. If it jumped time it would run bad at idle...maybe a fuel delivery issue or spark issue.
  5. Apr 21, 2013 at 12:52 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Just thought of that after I hit enter lol. I was thinking of valve float at high RPM, but that happens primarily with pushrod engines that I'm more familiar with.
  6. Apr 21, 2013 at 12:55 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    HMMM !
  7. Apr 21, 2013 at 1:03 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    The timing belt was replaced 2000 miles ago. The truck only has 91k. Just removed the timing cover and it hasn't jumped time... It feels like it hits a wall when it misses... Just removed both cam and crank sensors, no cracks in them...
  8. Apr 21, 2013 at 1:04 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    I would say valve float, but this is happening around 2500rpm and up...
  9. Apr 21, 2013 at 1:08 PM
    camt10
    camt10 Well-Known Member
    03 ext cab sr5 trd 4x4
    Lights flashing indicating catalyst poss damage usually indicating lean mixture if you have access to a fuel gage attach and monitor under load see what psi is doing. That's a start also if u have access to a cheapo scan tool see what fuel trim and oxygen sensor readings r
  10. Apr 21, 2013 at 1:13 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    I was pondering fuel pressure too.
  11. Apr 21, 2013 at 3:11 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    Update, p1135 o2 code just popped up... Going to Advance to pick up a denso sensor. Thanks to any and all who have helped so far. What is fuel pressure supposed to be? I did not see any test ports on the fuel rail?
  12. Apr 21, 2013 at 3:45 PM
    camt10
    Did u test the sensor output,ie resistance check could be bad if its original which sensor is that can't remember is that pre cat or post.fuel psi if I remember is around 40 either way should be constant what u would be looking for if it was an issue is drastic decrease when engine exhibits mis.no fuel Schrader u have to tee in to fuel line.who knows you might get lucky with o2 sensor if u need specific info I can get it at work tommorrow.
  13. Apr 21, 2013 at 4:24 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    Short term is 0% lt is 10.2%... My upstream sensor 1 o2 is showing 0v at idle. When throttle is pressed it hits .72v. I'm gonna start there and hope this works...
  14. Apr 21, 2013 at 4:35 PM
    camt10
    At 2k rpm does the sensor cycle or stay constant o2s should cycle
  15. Apr 21, 2013 at 5:06 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    cycles .2-.4v
  16. Apr 21, 2013 at 5:31 PM
    camt10
    Check that the sensor has its full range ie lean mixture out see out put
    Richer check output
  17. Apr 21, 2013 at 6:24 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    Well trying to remove the sensor the stud to the converter broke, cross threaded... Whomever owned this taco before me did a number. Found an exhaust leak near the sensor, and it's a Bosch 02... The factory converter looked to be running pretty hot, gonna change it.
  18. Apr 21, 2013 at 6:47 PM
    camt10
    Is the element in cat melted? They do run pretty hot,also what stud,mounting stud for 02?
  19. Apr 21, 2013 at 7:08 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    ya stud for the dang o2... The cat was almost glowing red, and caked with red clay! I've been scraping clay off of this thing since I bought it. I don't know if the element is melted, but I dont see how else to replace the stud...
  20. Apr 21, 2013 at 7:12 PM
    camt10
    Is the stud flush or some sticking up
