HELP!!! bad bucking and jerking
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacocass, Apr 21, 2013.
  1. Apr 21, 2013 at 7:19 PM
    tacocass
    tacocass [OP] Active Member
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    BIL 5100'S, PRO-COMP 1" REAR BLOCK, DECK PLATE MOD W/ KN
  2. Apr 21, 2013 at 7:27 PM
    camt10
    camt10 Well-Known Member
    03 ext cab sr5 trd 4x4
    The stud is threaded in,either drillntap or if you have access to a mig welder,place a 12mm nut over broken stud weld nut to studn pull it out with that mileage I doubt waxy outs will work
  3. Apr 21, 2013 at 7:38 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    cool, may try that. with 2 kiddos, I don't have much time.. lol thanks for all the help btw! I still don't know if this will even fix my problem....
  4. Apr 21, 2013 at 7:43 PM
    camt10
    No prob goodluck,no the feeling2 girls,2 dogs,engine in my garage to tear down,and a sequoia frame waiting for me to finish at work tom
  5. Apr 22, 2013 at 6:18 AM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    Magnaflow cat ordered. I will follow up after cat and o2 are installed...
  6. Apr 22, 2013 at 1:40 PM
    tacocass
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    I took the truck to my buddies shop. We hooked up the pegisys and it wouldn't communicate with my truck.... My friend has 3 of these truck, and knows them well. He started jiggling the ground harnesses... sure enough the engine ground was loose. A little blue lock-tight and we are back to normal... damn the small things!
  7. Apr 23, 2013 at 6:11 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    WOW --engine ground-never would have thought that could be it.
    GOOD its FIXED.
