Help....Bent Alignment Cam Tabs
Discussion in 'Suspension' started by derekdadagger, Mar 7, 2011.
  1. Mar 7, 2011 at 9:48 PM
    derekdadagger
    derekdadagger [OP] Member
    Derek
    Hinesville, GA
    Lifted 2010 Tacoma Double Cab
    3" Tuff Country lift, 17" Black Fuel Octane Wheels, 32" Nitto Tires, Black Eagle Eyes Headlights, Tint Windows, Roof Rack
    So I got my 2010 Tacoma all lifted with new wheels/tires and looking nice. Went in for the final touch.....a simple alignment. They end up breaking part of one cam tab and seriously bending and gouging the others, just on the passenger side. I know the bolts weren't frozen in the bushings and the truck only has 4,500 miles on it. So, has anyone had any experience with the TC cam gussets. Also does anyone know of any GOOD Suspension Fab shops around the Rowlett, TX ( East Dallas) area that could bend the tabs back and weld a supporting bead behind them? Thanks
  2. Mar 7, 2011 at 9:53 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Wow make them pay for their shitty work
  3. Mar 7, 2011 at 9:58 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Wow they fucked those up! It took me hitting a boulder at 45 mph to bend mine flat like that haha
    Anyways Total Chaos sells some ultra beefy replacements for your truck. THey are $90. You will have to weld them together then have them mounted to the frame by welding them. You have to air chisel the old ones off. Note: this how to do it the best way possible.
    If you wanna do it cheap by some 1/4" thick 1" tall flat stock and cut them out and have them welded to the mounts. Make sure you take off your LCAs so you don't melt the bushings
  4. Mar 7, 2011 at 10:14 PM
    derekdadagger
    Derek
    Hinesville, GA
    Yeah this shit pisses me off!!! You work so hard to make your things look nice and one inexperienced shop F's it up. This is why I do all the work myself on my truck. "amaes" is it $90 for all 8 to do passenger and driver's side? Thanks
  5. Mar 7, 2011 at 10:18 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
  6. Mar 7, 2011 at 10:26 PM
    derekdadagger
    Derek
    Hinesville, GA
  7. Mar 7, 2011 at 10:29 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    wow, looking at shit like this really makes me scared to get mine aligned. i do everything i can by myself because i'd rather f-it-up myself than let someone else f-it-up for me! I've even been looking into doing an alignment by myself and I've figured out how to measure for and adjust toe, and how to measure camber...but i have not been able to figure out how to actually adjust camber and caster.
    The second picture you posted: Is that the mechanism used to adjust either the camber or caster?
    I've been thinking that most guys on here say they just get their alignment shop to get them as close to 0 degrees camber as possible, and then they just max out their caster.
    Would this be something I'd be able to do? I guess what I'm asking, is if I was able to measure and adjust my camber to 0, could I just max out my caster and be as good as it's gonna get, regardless of who did it?
    and OP, sorry for hijacking the thread..if you'd rather me move this post i gladly will. Sorry that happened to your truck man.
  8. Mar 7, 2011 at 10:56 PM
    derekdadagger
    Derek
    Hinesville, GA
    The second picture is of the Toe Adjust Plate
