Help better towing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by t2khonda, Oct 10, 2017.
  1. Oct 12, 2017 at 6:49 PM
    #81
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    You know what's funny? If you google tacoma towing or second gen towing capacity, you get a bunch of threads from 2013 talking about lack of power towing, towing at 4K RPM's, getting 8-10 MPG, and talking about how they didn't get a Taco to tow with anyways. Now suddenly since there is a new gen to shit on, second gen owners and disgruntled third gen owners have pushed the second gen to some throne that it only achieved with rose colored glasses.
    And as far as I know, any direct towing comparison between the 2 had the third gen dumping all over the second gen.
  2. Oct 12, 2017 at 7:08 PM
    #82
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    You're suggesting I make and post a video of me laying rubber pulling away with a heavy load? Ok, if I get 10 likes on this, I would consider this as a genuine interest. i have no reason to lie about the abilities of the gen2... they are well known.
  3. Oct 12, 2017 at 7:11 PM
    #83
    Lt. Dangle
    Ohio
    Yeah, they are.
    Do what ever you gotta do, but you're the one making extraordinary claims, so provide some extraordinary proof as required.
    archerm3, =JSG= and Simpleton like this.
  4. Oct 12, 2017 at 7:11 PM
    #84
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    :popcorn:
    In for vid, folks like the post above for good vid potential.
    Edit:it's up 2 now. I used the slow type font tonight.
    tonered and Simpleton like this.
  5. Oct 12, 2017 at 7:12 PM
    #85
    Lt. Dangle
    Ohio
    I gave it a like.
  6. Oct 12, 2017 at 7:42 PM
    #86
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Bye. :wave:
    Herniator likes this.
  7. Oct 12, 2017 at 7:44 PM
    #87
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    :burnrubber:
    tonered likes this.
  8. Oct 12, 2017 at 8:50 PM
    #88
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    This is what I tow during the race season. 14’+2.5’ v-nose. Haven’t scaled it loaded so I am unsure about the actual loaded weights but I anticipate it to be around 3500lbs loaded. Everything inside is built from aluminum to keep weight down.
    In my experience the weight is less of an issue compared to wind resistance / aerodynamics. Around town and when accelerating I have no issues. Once up to speed or running down the hwy the wind resistance makes the biggest problems in terms of “load” vs weight. To be accurate the owners manual says tow in no higher than 5th and use ect (if nessecary but I usually don’t). I find that the weight / aerodynamics forced me to use 4th as 5th only comes into play on downhill sections.
    Now my fuel economy takes a serious hit when towing my parachute. I would hate to try and tow from one coast to the other. For that kind of travel I WOULD want a full size. But for 6-8 trips a year of under 1000km round trip I am able to live with it considering I get the perfect sized truck for the other 350+ days I year don’t need to tow. If you tow more often, longer distances or approach the tow limits regularly then once again maybe consider a larger truck.
    tonered likes this.
  9. Oct 12, 2017 at 10:16 PM
    #89
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Use 5th if it gives enough power to hold speed. No worries. The axle ratio is relatively low in the MT. The "don't tow in OD" thing is just a rule of thumb. Mostly for ATs where it would cause excessive shifting and TC slip (heat). I tow a light utility trailer in 6th and my little '47 jeep in 5th (~3,500lbs including dolly). 5th in the MT is about the same as 4th in the AT....just a bit higher. A very good towing gear.
  10. Oct 12, 2017 at 10:57 PM
    #90
    TRDPro75
    TRDPro75 Well-Known Member
    Victor
    North Seattle
    2017 TRD Pro Cement Auto
    NitroGear 5.29 Regear OVTune 2.O Tune TRD Cold Air Intake TRD Pro Stock Exhaust 285 75X65 Gladiator X Compe 2020 OEM TRD Pro LED Headlights SnugTop GB Sport Canopy RIGID 30” Radiance Light Bar RIGID 40” Radiance Light Bar Custom Avente Roof Rails on Snugtop Icon RXT Spring Stage 3 Fox 2.5 Tundra Rear Shocks CBI Covert Bumper RCI Full Aluminum Skids RCI Rear Diff Skid RCI 20° Sliders ExperiMental Designs Anytime Locker Wilco Offroad Hitchgate Offset to Passenger Spare Carrier
    Honestly try getting the OVTune. I’ve been extremely happy with the tune and it gave me much more useable power and torque throughout the midrange.
    Up to 30+ ft lb according to OVTune and it’s noticeable. I had a 2005 4.0 4Runner before this and yes it had more torque than my now Tuned Pro in 1st and maaayyybe 2nd but I now produce way more power beyond that. And I run 33’s.
    Bet it would help! And your ECU can be reflashed to stock if something ever went wrong for warranty so the dealer would never know. Talk to Mathew at OVTune and ask about towing. I’m not sure how his revised shift points on the 1.02 version would affect a 6,000 pound trailer (in terms of how close to redline you might get) if you really mashed on it. My guess is you’ll be much happier.
    https://www.ovtuned.com/collections/tacoma/products/toyota-tacoma-2grfks-calibration
    tonered likes this.
  11. Oct 13, 2017 at 9:12 AM
    #91
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    Regear.
    Be honest to yourself how often do you actually tow the boat? Just rent a big truck. Then you arent driving a huge truck around for the 99% of the time you arent towing.
  12. Oct 13, 2017 at 9:20 AM
    #92
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Clever, love that, fave movie.
    SwollenGoat[QUOTED] likes this.
  13. Oct 13, 2017 at 3:33 PM
    #93
    Lt. Dangle
    Ohio
    Post has 10 likes.
    You talked the talk, now walk the walk.
  14. Oct 13, 2017 at 4:14 PM
    #94
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Now you have to be patient as I don't have any loads to haul at this time. Next time I go to the saw mill to pick up, I will make a short "Errrt" video for ya.
    Spare Parts likes this.
  15. Oct 13, 2017 at 4:23 PM
    #95
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I'm not sure why some are complaining of the 3.5l for towing. I tow a RV that weights in at around 3700 lbs with my 2012 Tacoma auto (4 speed) with a 2.7l. The truck pulls the trailer fine on flat ground and run at speeds between 60 and 65. The truck only has 160 hp. This year we went out west to the mountains and even though the truck managed we just needed a little extra. I've ordered a 2018 TRD Sport with a manual and I'm confident that with more than 100hp over the 2.7 I won't have any issues.
    21' Jayco Skylark
    kgilly, tonered and Spare Parts like this.
  16. Oct 13, 2017 at 4:58 PM
    #96
    Lt. Dangle
    Ohio
    Patient?
    Fuck it, I'm out lol.
    archerm3 likes this.
  17. Oct 13, 2017 at 5:06 PM
    #97
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Hang in there buddy! I won't forget ya. :cheers:
  18. Oct 13, 2017 at 5:13 PM
    #98
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Or get a smaller boat? Wow the problems we have, right....
    tonered likes this.
  19. Oct 13, 2017 at 5:27 PM
    #99
    blksandpearl2010
    blksandpearl2010 Yeah, yeah...
    NC
    2010 LB trdSport
    old man emu, nitrocharger shocks, darkar leaf springs, bbs wheels, access tonneau cover, laufen AT 275/65/18,
    1st world problems :amen:
    kgilly[QUOTED] and tonered like this.
  20. Oct 14, 2017 at 7:08 AM
    #100
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Take your time, steadfast, you don’t have to prove anything. We’re all guilty of rhetorical hyperbolation from time to time, and no one except Lt. Dangle is going to hold it against you. Even if you demonstrate your claim, it’s a meaningless test, and depends more on tongue weight than anything else. Anyone who tows a lot knows that. Relax.
    Steadfast[QUOTED] likes this.
