Help? Block Heater!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mike27, Jan 3, 2009.
  1. Jan 3, 2009 at 6:09 PM
    mike27
    mike27 [OP] New Member
    2007 V6 SR5, TRD, White
    This past summer I purchased a new unused 2007 Tacoma V6 SR5, the bill of sale states that my truck is equipped with a block heater. But I can't find it anywhere on the engine.:confused: Can anyone tell me where the block heaters are typically mounted on the engine? If you could give as much info as possible or even provide me with a picture it would be greatly appreciated.
    Thanks,:)
  2. Jan 3, 2009 at 6:10 PM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    I believe its on the passenger side of the engine towards the back. Dont quote me on this but I had inquired about having one installed prior to getting my taco but ended up not needing it after all...at least not for now. Good luck with the search
  3. Jan 3, 2009 at 6:17 PM
    mikeyramone
    mikeyramone 220 - 221 Whatever it takes
    Westfield,Ma
    2005 4X4 TRD Sport Speedway Blue
    Sylvania Silverstar headlights, vent visors, Advantage Tri-fold tonneau cover, pop n lock, Sirius radio, auto dimming mirror, AFE Pro-Dry air filter, secondary air filter removed, Magnaflow muffler, Hood scoop decals, Painted grill, Devil Horns!!!
    not to be a smart a$$ but did you check out the owner's manual? But if I remember correctly I think it is usually installed on the middle freeze plug on the passenger side.
  4. Jan 3, 2009 at 6:25 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    The block heater on the V6 is on the driver side of the engine. It is installed into a hole in the back side of the block just under the head.
    You can narrow your search to the driver side for the cord.
    There are some pics on TN if you can't seem to find it.
    Here, I found a picture. Picture is taken from driver side near the brake master cylinder.
    Marc M
  5. Jan 3, 2009 at 6:29 PM
    obxfishn
    obxfishn Well-Known Member
    Eastern Virginia
    2.5" ToyTec Lift, Smitty Built Nerf Bars, Scangauge unit,
    Correct...Just look for the starter and its located directly behind the starter towards the back D/S bottom of block. Just look for the black power cord. I believe the end of the heater where the cord attaches is red. Good luck.
  6. Jan 3, 2009 at 7:08 PM
    mike27
    Thanks, everyone! :)
