Help! Blue Smoke 09 Taco!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TodaGuy, May 25, 2009.
  1. May 25, 2009 at 3:54 PM
    TodaGuy
    TodaGuy [OP] Well-Known Member
    Oregon
    Almost Murdered 09 Taco
    Revtek 3" spacer in front 1" block w/ 2" AAL in rear. Blacked out grill, debadged (almost all done), Magnaflow muffler, black Konig Countersteer Off Road rims, 285/75/16 Toyo Open Country M/Ts.
    Well I had surgery on Friday and My truck has not been drivin sense thursday afternoon until today (Monday 2pm). When I got in my truck and started it up a big cloud of blue smoke rolled by my passenger window:eek:! I noticed blue smoke a couple of times during the winter on startup when we had lots of snow and cold weather. The truck had also been sitting for a couple days. The truck is a 09 with almost 10k miles. I took it to the dealer during the winter and it sat there for a day or 2 and when they started it up they didnt see any smoke. They documented it and said they can put me on a oil consumtion watch... I switched to syn motor oil last oil change about 700 miles ago. What the hell is causing this smoke?
    Thanks
    Bret.
  2. May 25, 2009 at 4:00 PM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    I don't have the same problem with blue smoke, but i did notice that in the winter my exhaust was more prevalent than all of the other vehicles on the road. Had me worried. If you have a smog place nearby they could probably tell you what kind of pollutant you are releasing and you might be able to trace it backwards. Sorry i couldn't be more help, but if this were an older car i would have better info.
  3. May 25, 2009 at 4:02 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    My truck can sit for two weeks and I don't notice any blue smoke... but I will check next time she sits for a few days.
    If you've had it to the dealer and they didn't see any smoke, next time it sits a few days, have a video camera set up and tape the smoke...
  4. May 25, 2009 at 4:05 PM
    TodaGuy
    Oregon
    Ya I would have done that this time but I did not think this would happen when it wasnt cold out. I thought the cold weather had something to do with it when I first noticed it.
    Im very concerned about this...
  5. May 25, 2009 at 4:06 PM
    justindwhite
    justindwhite Member
    tulsa ok
    06 tacoma trd 4x4
    As I'm sure you know the blue smoke is oil. It sounds like to me it could be a valve guide. I would try to take it to the dealer agin on a hot day after you drive it for about 100 miles or so to make sure that the engine is warm and park it. If it is a valve guide the hot oil in the head will have a lower viscosity (be thinner). That will allow it to flow into the cylinder and will cause blue smoke on start up. Or try it at your house first to save you the trip.
  6. May 25, 2009 at 4:07 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    could be a leaky valve guide. nearly impossible to verify without a teardown, but not doing much harm unless it gets worse....
  7. May 25, 2009 at 4:07 PM
    wormhole7
    wormhole7 Well-Known Member
    Lake Dallas, Tx
    TSS
    Leather, Suspension TSB, Billy 5100's up front set at .85, Eaton Posi LSD,Grillcraft Black Mesh Grills,Aires Bull Bar,Black Low Profile Narrow Toybox,Black Headlight Mod,Black Tail lights ,USA Spec,Ipod, PopnLock,Bed Mat,Bug Sheild,Vent Visors, Weathertec Liners,Radar,Nuvi 760,Dog Ramp,Convex Mirrors, Roof Rack, Tint, Borla exhaust, Borla Intake, OBX pedals, Home Link Auto Dimming Mirror with remote, 20" Factory Wheels, Factory Tube Steps
    Mine did that after I put too much oil in it. I had to drain some out and haven't seen it since.
  8. May 25, 2009 at 4:31 PM
    TodaGuy
    Oregon
    So its possible the dealer put too much oil in the truck when it was in for a oil change?
  9. May 25, 2009 at 5:19 PM
    justindwhite
    justindwhite Member
    tulsa ok
    06 tacoma trd 4x4
    yea to much oil could cause higher than normal block pressure and sling to much oil on the crank. just check the oil and see. I have ran into some things that the dealer did that where wrong so just cause they do it does not mean its always correct. I have learned to always check there work.
  10. May 25, 2009 at 9:09 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    its under warranty.. take it in and get it checked out. Blue smoke = bad. Get it taken a look at
  11. May 25, 2009 at 9:18 PM
    TodaGuy
    Oregon
    I took it to the dealer when i first saw it happening and they said they didn't find anything wrong with it. they said they can put me on an oil combustion watch..
  12. May 25, 2009 at 9:20 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    oil combustion watch..? okay sounds good to me! Just keep an eye on it..
  13. May 25, 2009 at 9:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  14. May 25, 2009 at 9:27 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    mine does it just a tiny bit...but what do you expect from 129,000 miles? Just keep and eye on the oil level.
  15. May 25, 2009 at 9:27 PM
    TodaGuy
    Oregon
    Ya that have you bring the truck in every few weeks to check the level on the dipstick. I going to check the dipstick tomorrow when the truck is parked on level ground. Its on a real slanted driveway right now.
  16. May 25, 2009 at 9:33 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    let the truck blow the motor..then you dont have to worry about any problems when your out of warrenty:D
  17. May 26, 2009 at 6:53 AM
    TodaGuy
    Oregon
    I'm gonna let the truck sit all day today and video tape the exhaust on startup to see if i cant catch it in the action on tape.
  18. May 26, 2009 at 11:23 AM
    TodaGuy
    Oregon
    I started the truck but no blue smoke on initial startup although the first time i punched the throttle to about 2200rpms (the first rev you hear) it blew out some blue smoke. The truck sat for 16 hours or so...
    http://www.youtube.com/watch?v=Vn4rZu289Oc
  19. May 26, 2009 at 12:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hard to tell the color of the smoke in the vid....It kinda looks like water vapor, wich is normal. Has your oil level been dropping since this has been discovered?
  20. May 26, 2009 at 12:28 PM
    TodaGuy
    Oregon
    Ya i should have had the camera further away from the truck. When i looked in the side mirror i could see the lingering blue. I have not checked the oil yet because the truck is on a slope. Im headed out for a few things ill check it when i get back.
