Help..bought used Tacoma yesterday problem already!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bellainkette, May 13, 2012.
  1. May 13, 2012 at 12:55 PM
    bellainkette
    bellainkette [OP] New Member
    Bella
    southern maine
    tacoma 2005 4.0 6cyl
    Ive had my 2005 4x4 4.0 6cyl automatic trans. since yesterday. Bought it from a used car dealer. On the way home from the dealer 1.5 hours away. Engine light went on. I parked truck when i got home and started car again and truck would not move forward when i put car in DRIVE. Engine REVed with out kicking into gear. Turned engine off and started truck again and put shift into DRIVE once again. Truck advanced forward this time, but once i drove car again on the road. Its been struggling and Reving engine inbetween gear changes. One minute it seems fine the next min it acts like this....Its definately not right...Anyone with any insight is greatly appreciated.
  2. May 13, 2012 at 12:57 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Really hope you got a warranty >_<
  3. May 13, 2012 at 1:01 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    For starters quit driving it and check that CEL (don't clear it).Write it down then call that dealership.
    See what they can do ,since you did buy it yesterday.
  4. May 13, 2012 at 1:07 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    x2 even if it was use there are laws and rigths on your side.....
  5. May 13, 2012 at 1:12 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Take is back now. Dont screw with it or anything. If they dont take the truck back get them to give you a extened warrenty or tell thrm that they will be hearing from your lawyer
  6. May 13, 2012 at 1:15 PM
    bellainkette
    Bella
    southern maine
    No hard shifting or slamming on the 65 mile ride home. It all started once i turned truck off and got home. I had a mechanic at Ford Dealer check it out for me down the road from the dealer before i signed on the dotted line too??? He said it was in good shape...???? My warrenty is lousy. 30 days or 1000 miles drive train warranty 50/50 split buyer/dealer on issues. Where can i look up my rights, looks like i may need it!! Im so bummed.
  7. May 13, 2012 at 1:19 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
  8. May 13, 2012 at 1:27 PM
    pgreeny
    pgreeny Member
    Dayton OH
    07 Prerunner DBL Cab
    I am a tech at a Toyota dealer. If it set a pressure code its usually low on fluid. Most times what we have seen is someone drains the trans fluid rather than oil. There is a fill procedure. I would go to a Toyota dealer and have it checked Asap. Usually those transmissions are bullet proof. Good luck.
  9. May 13, 2012 at 1:39 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    You have a 30 day 1000 mile warranty on it so call the dealer and have them haul it in for the warranty work. Don't drive it. Like someone above said they may have drained the tranny instead of engine oil. Maybe check the engine oil to see if it's overfilled.
  10. May 13, 2012 at 1:55 PM
    pgreeny
    pgreeny Member
    Dayton OH
    You would be surprised how often we see this. Not saying that's it for sure but it has become pretty common. We've had 2 Tacomas and a Matrix in the last 90 days or so like that. Usually once corrected they are fine.
  11. May 13, 2012 at 2:09 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yep low fluid level.
  12. May 13, 2012 at 4:43 PM
    rdd11
    rdd11 Well-Known Member
    Ross
    Red Deer, AB
    08 TRD Double Cab long box black
    K&N cold air, Exhaust
    Go check the transmission fluid right now. If its low put some in and keep an eye on it for a while
  13. May 14, 2012 at 2:22 PM
    bellainkette
    Bella
    southern maine
    UPDATE!! So...I went to Toyota dealer this morning..had my new truck towed. What they found was a electrical problem. They said the wiring harness and junction box needs to be replaced. The part is 1850 and the labor 600. OUCH!! I was told that the symptoms my truck has been expierencing with the transmission was characteristic of this harness problem. Anyone ever had this problem with their 2005 tacoma automatic? my truck only has 80,ooo miles on it. The good news, I hope is that the used car dealer said he was going to investigate and fix the issue. Hope he says the same thing as the dealer now. He also put me in a loaner car. Tommorrow i should know more....
  14. May 14, 2012 at 2:30 PM
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    how lame id ask for some freebies
  15. May 14, 2012 at 2:32 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    Most states have lemon laws if the dealer gives you a hard time about the vehicle. The law requires them to take the vehicle back if there are valid issues that were not stated in the contract. Here is yours.
    Chapter 07: The Maine Lemon Law And State Arbitration
    Under the Maine Automobile Lemon Law, if the consumer reports serious defects to the dealer or manufacturer during the express warranty period, within three years of the date of delivery or during the first $18,000 miles of operation (whichever is earlier), the Lemon Law requires the manufacturer to make the necessary repairs. If the manufacturer cannot fix the car, then the consumer has the right to argue the case before a State Arbitrator, free of charge. This hearing must come within 45 days of acceptance of the Lemon Law application and if the Arbitrator concludes that the car is indeed a Lemon, the consumer can receive either a new vehicle or the return of the purchase price.
    Chapter 7: The Maine Lemon Law And State Arbitration (PDF) This file requires the free Adobe Reader.
    If you have a question about this chapter or cannot access it, please contact consumer.mediation@maine.gov.
  16. May 14, 2012 at 2:49 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    ^^ Make sure you read that PDF file that is linked. Most likely you will NOT be covered under the lemon law. A Lemon Law covers you if you have the same issue repeatedly and they are unable to correct the problem, or the problem keeps coming back, not a one time issue. Read the PDF before you march into a dealership barking about a Lemon Law because it doesn't apply yet.
  17. May 14, 2012 at 2:59 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If you continue to have problems and the used car dealer you bought from doesn't take care of it mention to them that you talked to the local news about doing a story on them to showcase their exceptional customer service.
  18. May 14, 2012 at 8:51 PM
    stangkeip10
    stangkeip10 Well-Known Member
    Cincinnati
    '10 Magnet Gray 4x4 Access Cab SR5
    BHLM, Black OR TRD wheels, BFG Mud terrains, yellow wire mod, 5100s @ 2.5, toytec tsb aal
    sounds like the 30 day will take care of it hopefully. best of luck.
  19. May 14, 2012 at 8:59 PM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    good luck sucks to go through this when you get a new vehicle
  20. May 15, 2012 at 7:26 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    What happened OP any news?
