HELP! Brake Lights Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DCCHIRO, Aug 7, 2020.
  1. Aug 7, 2020 at 2:50 PM
    DCCHIRO
    DCCHIRO [OP] Member
    Bardstown , KY
    2010 Silver DC SPORT
    ICON Stage 7 Suspension
    My brake lights are malfunctioning. Rear top cab brake light works just fine (it’s the only one). When head lights are OFF and I brake it’s the only one that works. Other two (L) (R) brake lights stay dark. When the headlights are ON the (L) brake light stays on (like I’m breaking continuously) regardless if the brake is pushed or not. The (R) brake is backlit when the headlights are ON and go off completely when I push the brake. What gives?
  2. Aug 7, 2020 at 2:54 PM
    Clearwater Bill
    Billy
    Largo Florida
    Any wiring mods? LEDs? Auxillary lighting? Aftermarket trailer plug?
    DCCHIRO[OP] likes this.
  3. Aug 7, 2020 at 3:34 PM
    DCCHIRO
    DCCHIRO [OP] Member
    Bardstown , KY
    I did Ultimate Headlight Upgrade w/ Rigid Fogs years ago and everything’s been working fine. All the lights have been LED upgraded. I’ve got a fully loaded SwitchPros for auxiliary lighting. It does tap into my HighBeams Wire.
    It did most of it myself and it’s been working fine for years now. I’m no pro though so...
  4. Aug 7, 2020 at 3:55 PM
    DCCHIRO
    DCCHIRO [OP] Member
    Bardstown , KY
    Rechecked it and things have changed. Now it just appears like the (L) brake light is out when the brake is pressed. The backlight is still working though. Just doesn’t go deep red when brake is pressed. Could it be just a bad bulb on left side causing all this? Got bulbs coming
  5. Aug 7, 2020 at 3:56 PM
    DCCHIRO
    DCCHIRO [OP] Member
    Bardstown , KY
    Right brake and middle light are working now just to clarify
  6. Aug 7, 2020 at 4:01 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    The first thing I'd do is go back to "stock" (non-LED) tail / brake light bulbs just to see what happens. With standard bulbs, you either have a complete circuit through the filament or you don't. With LED bulbs, you have a whole bunch of circuitry driving the actual LED. When that circuitry goes bad, weird things can happen. Try that and get back to us. Don't drive around without proper brake lights.
  7. Aug 7, 2020 at 7:37 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    LED Conversion Problems. :annoyed:
    DCCHIRO[OP] and Too Stroked like this.
