HELP Brakes pulsate and shake....gen 1
Discussion in '1st Gen. Tacomas (1995-2004)' started by tskub, May 31, 2016.
  1. May 31, 2016 at 10:02 AM
    tskub
    tskub [OP] New Member
    TOM
    2004 quad cab 4x4
    Before you suggest to me its the front rotors ..I have replaced them ....twice (new pads and upgraded to TUNDRA front hardware)....plenty of stopping capacity. The rears got new drums and shoes and it still pulsates when slowing down. You can feel it in whole truck and higher speeds really shake it up.
    IF I pull the E brake at about 40 miles per hour (easing it out) I get the same exact sensation so I know it is in the rear but not "fluid brake based issues". I took the old drums and had them turned just to confirm that the new ones were not bad and put them back on this weekend and same problem.
    I am struggling to understand what could be the cause of the problem?????
    Anyone ???
  2. May 31, 2016 at 10:04 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Heh, my rear brakes pulsate a little bit too, especially if I drive with the e-brake on. Not sure what it is may be warped in a lateral direction or a shitty pad seat. Couldn't tell ya for sure.
  3. May 31, 2016 at 6:28 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    If a shop did the work (rear brakes), take it back.
    If you did it, and are new at it, you may have messed up something. Lots of little parts that have to go back exactly right.
    I have a '99 and some things may have changed by 2004
    Does yours look like this? :
    I have some better photos that I could dig up, including the bottom portion, if you want.
  4. Jun 1, 2016 at 1:12 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your wheels are torqued uneven as one nut really loose or tight compared to the rest it will cause a shaking just like warped rotors or drums
    Worn suspension parts can cause this as well.
  5. Jun 1, 2016 at 1:26 AM
    Tom0662
    Tom0662 Well-Known Member
    Tom
    Iowa
    2016 TRDORSB
    End of axle shaft bent??? That night you had a bit too much and
    were out doing donuts and hit that curb??? Remember?? J/k :boink:
    But seriously, maybe end of axle shaft bent. Jack the rear
    and spin the wheels and see if they wobble. Just a thought
  6. Jun 1, 2016 at 2:56 AM
    spinglow
    spinglow Well-Known Member
    cory
    Oregon
    2015 tacoma dcsb trd off road
    Maybe air in the Master cylinder you might have to bench bleed it!!!!
  7. Jun 1, 2016 at 3:33 AM
    tskub
    TOM
    2004 quad cab 4x4
    Thanks I'll put it up on stands and see if I can narrow it down to one side.
    Doubt it is air in line as it occurs with ebrake which is completely cable driven so we are talking mechanical parts.
    Yes mine looks like your 99 but I have been over it and everything is place and operational.
  8. Jun 1, 2016 at 5:06 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    Get some new Brembo brake drums, around $120 for the pair, mine shook terrible, completely smooth & nice now. Also installed Wagner shoes with the drums. Check the runout on yours with a dial indicator, mine were .025", way too much.
  9. Jun 1, 2016 at 11:00 PM
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    The way mass produced parts are anymore it is possible you got a bad drum, who
    knows. There isn't a chance that you have some rust buildup on one spot of the
    axle flange not allowing the drum to sit right?? Good luck on your quest for the fix.
  10. Jun 2, 2016 at 8:11 AM
    NvrSyNvr
    NvrSyNvr Well-Known Member
    Jim
    2000 Green PreRunner Xcab V6 Auto w/locking diff
    Hayden 678 Transmission Cooler
    I had a similar situation with brake pulsation. I replaced the front rotors and pads twice. I believe that bleeding the brake lines (including at the proportioning valve) and torquing the lug nuts to spec helped. But, what ultimately took care of the issue was changing the rear drums, shoes and hardware about a month ago. Now the brakes are smooth as glass.
    BTW, I like the handbrake test. Makes good sense.
  11. Jun 2, 2016 at 8:22 AM
    Norcal89
    Norcal89 Active Member
    San Francisco
    Black 2003 2.7L Regular Cab 4x4 5 Speed
    Wheel or tire could be out of round
  12. Jun 2, 2016 at 7:03 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I had same problem. New pads and drums/rotors all the way around. I went and had my new rotors and drums turned..... fixed the problem. The drums were warped off the shelf. .
  13. Jun 2, 2016 at 11:43 PM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Which rear drums did you go with? I bought Napa versions once and they were warped right out of the box.
    Also it could be that your auto adjusters were not installed properly.
    RJM
  14. Jun 3, 2016 at 4:28 AM
    johnny3
    01 Tacoma TRD
  15. Jun 3, 2016 at 3:57 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    If your truck has ABS it can cause similar issues to what you are describing.
  16. Jun 14, 2016 at 12:23 PM
    tskub
    TOM
    2004 quad cab 4x4
    To all: thanks for notes and insights. I hit the wall and literally turned it over to Toyota. The replaced all rear brakes components with FACTORY parts and now I smile when I brake.
    Yep 510 dollars later smooth as it gets. I did take the recently purchased parts back to autozone and they gave me full refund. Pretty decent of them overall.
    Hope this helps the next guy.
  17. Jun 14, 2016 at 5:06 PM
    Toyota4x46921
    Michael
    Warner Robins, GA
    Yeah don't ever buy autozone brake anything .....unless it's brake cleaner lol
