Help, brand new truck...rear tire locked
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lawaspen, Jan 1, 2018.
  1. Jan 1, 2018 at 8:32 AM
    lawaspen
    lawaspen [OP] Member
    2017 Sport 5sp Access
    On month old and the back right wheel is locked, truck immobile.... any suggestions on this New Years Day when dealership is closed?
  2. Jan 1, 2018 at 8:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    Where are you? Frozen?
    9TRDTCO likes this.
  3. Jan 1, 2018 at 8:36 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Frozen? Several here suggest hammering (try first with a mallet or hammer with wood block) on brake drum, and also flex the brake cable with hands near rear wheels.
    Good luck, keep warm and Happy New Year.
  4. Jan 1, 2018 at 8:37 AM
    lawaspen
    I am so pissed, there is a recall on 2016 2017 Tacomas for this problem, why I wasn't made aware of that I don't know, its a differential problem and the wheel can lock up while driving, my wife could've been in an accident, this dealership is going to hear it I guarantee you that
    wilcam47 and outlawtacoma like this.
  5. Jan 1, 2018 at 8:38 AM
    lawaspen
    It is 45 degrees here and it happened in the garage where it is closer to 55
  6. Jan 1, 2018 at 8:41 AM
    OnHartung'sRoad
    Oh. Sorry about that, good luck!
  7. Jan 1, 2018 at 8:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Look before you jump.
    The recall is for specfic vins. You may or may not be included.
    The recall uses panic language, but the real deal is a leaky gasket and under torqued bolts. If your diff housing is dry you certainly haven't lost your fluid. You can pull your fill plug to check if it makes you feel better.
    You'd be the first around here to have an 'actual' failure.
    I'm guessing the ebrake is stuck for some reason.
    poopshute, Bray1197 and MCDavis like this.
  8. Jan 1, 2018 at 8:45 AM
    skylinekin
    skylinekin Member
    If you have the tools & time, pull off the wheel and drum (using bolts) on that side, cycle the parking brake a few times then reinstall everything. Worked for me in an emergency where I could not get to the dealer.
    Hasn’t happened since fortunately!
  9. Jan 1, 2018 at 8:46 AM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Put it in 4lo and back up for 10 feet and it will probably let go
  10. Jan 1, 2018 at 8:46 AM
    skylinekin
    skylinekin Member
    Mine was stuck enough it wouldn’t budge in 4lo..
  11. Jan 1, 2018 at 8:47 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    The "frozen" rear drum is not necessarily related to below freezing temps.
    Was the truck exposed to water before you parked it?
    Might be a relatively easy fix to get it unstuck.
    Good luck.
    9TRDTCO and wilcam47 like this.
  12. Jan 1, 2018 at 8:49 AM
    lawaspen
    That worked!! Thanks Swiss Rally Man
    JGO, OnHartung'sRoad and boynoyce like this.
  13. Jan 1, 2018 at 8:53 AM
    OnHartung'sRoad
    Hey! I thought you had a sport, so I deleted my 4low advice. ;) Good news, though!
  14. Jan 1, 2018 at 8:55 AM
    swissrallyman
    No probs my 2nd gen used to to this during winter time for the first couple years... had toyota tear everything apart a couple times but nothing definitive ever found... sometimes pulling on the parking cable guide below the handle would work. But 4lo in reverse always did the trick.
  15. Jan 1, 2018 at 8:58 AM
    lawaspen
    We do have the sport
  16. Jan 1, 2018 at 9:01 AM
    OnHartung'sRoad
    Ah. I also had my 1st gen parked for a while, and the rear brakes frozen due to caked on silt from a low water crossing I did. One recommendation is to not use e-brake for parking on a flat.
  17. Jan 1, 2018 at 9:02 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    How do you have a 5 Speed in a Sport?
    eon_blue likes this.
  18. Jan 1, 2018 at 9:02 AM
    david-oregon2999
    david-oregon2999 Well-Known Member
    Can't wait to learn the root cause.
  19. Jan 1, 2018 at 10:54 PM
    lawaspen
    That's what I have, we ordered it from Toyota with the 5 sp and a bunch of the other options we wanted. Took 2 months to get but we weren't in a rush
  20. Jan 1, 2018 at 11:03 PM
    shakerhood
    Southern Ohio
    The only 5 Speed Manual in a 3rd Gen that I was aware of was the SR, and they even did away with that for 2018.
