Help - Broken Oil Filter
Discussion in 'Technical Chat' started by larryde09, Aug 24, 2010.
  1. Aug 24, 2010 at 6:37 PM
    larryde09
    larryde09 [OP] Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    So I finished my oil change and started the engine to check for pressure and any leaks. Sure enough, I had a steady drip when the engine's running. I looked up at the oil filter and I see the filter gasket sticking out one of the sides...I assume the gasket split during installation and got pushed out the side as it was tightened.
    Can I take the filter off without having to drain all of the new oil out of the pan first? It's a 2006 4-cyl, so the filter is way up near the fender. Am I correct to assume that since the filter is higher than the pan that only a little will come out just like any other time I change the oil. Also, if it sits over night, I'm guessing that most of the oil in the engine will drain to the pan instead of coming out the filter hole when I remove it.
    Basically I just want to know if I can easily change the filter without compromising the new oil and/or having a bunch of oil drain out the filter hole. I appreciate the help!
  2. Aug 24, 2010 at 6:42 PM
    GEARAHOLIC
    GEARAHOLIC Well-Known Member
    KELLEN
    PASO ROBLES, CA
    07 Black on Black BEAST
    pull the filter....verify a clean seal surface (no left over o-ring material) re-install new filter, should be minimal oil loss. Fire up the motor for a min or so, shut it off check oil leval and fill as needed...
  3. Aug 24, 2010 at 7:50 PM
    larryde09
    Larry
    Rochester, NY
  4. Aug 24, 2010 at 7:53 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
  5. Aug 24, 2010 at 7:54 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    The short answer is yes, you can remove filter with out draining oil :D
  6. Aug 24, 2010 at 7:56 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    This. If you fill the replacement filter with fresh oil prior to installing it oil loss will be negligible. Check for leaks, verify via dipstick, and go on with life.
  7. Aug 25, 2010 at 4:40 AM
    Barnone
    Barnone Guest
    Sounds like you left the old gasket in when you changed the filter and it got cocked.
  8. Aug 25, 2010 at 4:52 AM
    larryde09
    Larry
    Rochester, NY
    I thought this as well...normally I do a good job cleaning the area before installing the new one, but I was in a hurry to finish before dark...oops! I didn't notice if it missing on the old one, but I'll post what actually happened after I finish up today.
  9. Aug 25, 2010 at 7:52 AM
    larryde09
    Larry
    Rochester, NY
    Thanks for the help, it was in fact the gasket from the old filter...in my hurry to finish before dark, I didn't bother to clean up the area and certainly would have noticed the old gasket had I taken my time! Also, as expected, I removed the filter without any significant loss of new oil.
