Help buying toy 89 22re ticking noise
Discussion in '4 Cylinder' started by halogene, Apr 12, 2013.
  1. Apr 12, 2013 at 4:15 AM
    halogene
    halogene [OP] Member
    Canada/Quebec
    89 tacoma xtracab
    lift kit 3po front 2.5 rear 31po offset tire & rim
    What is nornal ticking noise for 22re i heard that these engine had a bit ricking noise but i am wondering if it is a safe buy how i can be sure is nornal noise or not crank bearing or rod bearing wis pin ... Help would be apreciate thanks you
  2. Apr 12, 2013 at 4:32 AM
    OldGeezer42
    OldGeezer42 Well-Known Member
    Adam
    Louisiana
    07 DCLB Silver Base
    Husky mats,30% tint all around, DTRL,OEM Bed mat,UWS Tool box,OEM fog lights,5100's,Wheelers 3leaf HD springs.OEM cruise control,OEM wipers,,Avid light bar,Flyzeye Leds,4x4 illuminated switch.Matt123 skids,bed lights,Ome 884s
    Is the sound coming from top or bottom and how many miles? Is it loud? Does it get worst if the engine is spend up ? It could be a bad lifter, or just a normal sound.
  3. Apr 12, 2013 at 1:22 PM
    halogene
    Canada/Quebec
    89 tacoma xtracab
    the truck is 2 hours far from me so i cant tell the sound i asked the guy to make a video of the truck and the frame everything but the video is to heavy to be sent... 185 000 kilo not miles what should i ask to him ? he said that the head just been planned and the valve sealed and ajusted by the garage probably not toyota garage.. thanks for reply!
  4. Apr 13, 2013 at 8:41 PM
    halogene
    Canada/Quebec
    89 tacoma xtracab
    i dont know if i made the good choise i bought it ... it have a exaust leak and 2 hole in the floor so we hear the exaust leak kinda a lot and here i have a video of the motor noise im gona post it
  5. Apr 13, 2013 at 8:49 PM
    halogene
    Canada/Quebec
    89 tacoma xtracab
    how can i post a video ? i make it in low quality so is not big at all
  6. Apr 13, 2013 at 8:59 PM
    halogene
    Canada/Quebec
    89 tacoma xtracab
  7. Apr 13, 2013 at 9:43 PM
    halogene
    Canada/Quebec
    89 tacoma xtracab
    diagnosticing* bymyself via watching youtube video it not sound like rod knock or winspin look like valve ajustment sorry for bad english guys.
  8. Apr 13, 2013 at 10:16 PM
    04tacomarob
    04tacomarob Well-Known Member
    Robert
    Fallon, NV
    04 Tacoma TRD
    Grey wire mod ToyTec ultimate lift
    Yeah, more than likely valves. The 3 I've had were all pretty noisy. Easy to adjust though. Instructions are everywhere and simple to follow :)
  9. Apr 13, 2013 at 10:20 PM
    04tacomarob
    Robert
    Fallon, NV
    04 Tacoma TRD
  10. Apr 13, 2013 at 10:38 PM
    halogene
    Canada/Quebec
    89 tacoma xtracab
    thanks for your reply tacomarob, i probably could do it myselft ? what you think about it ? i need a (gauge/gage) for mesurment isnt it ? coulnd find this on ebay probably or at local shop for cheap hope so and can i still use my truck wihtout break something ?
  11. Apr 13, 2013 at 11:18 PM
    04tacomarob
    Robert
    Fallon, NV
    04 Tacoma TRD
    Just buy some feeler gauges from any parts shop. Get the ones that are bent, the straight ones can be a pain. Easily doable by yourself. If you have money you could go to a shop, but it's pretty painless.
    I made them worse the first time I did them but after that it was easy.
